R 33 PARTS
r 33 engine head and block and intake manifold no exhauts side $1200 ono must sell
blitz froont mount conects up to original piping $650
e manage blue $300
r 32 PARTS
rear spoiler off a 4door 32 $60
front bumper m spec with lights $170
rear bumper $60
side skirts 2 door $120
ALL MUST GO CLEANING OUT SHED AND MOVING MAKE AN OFFER
LOCATION MELB CRANBOURNE
call me on 0401334464
Edited by slow_as_33
interested in side skirts.. please post more info.
what type of side skirts, what colour, genuine, etc etc..
and location please.. will pick up off you if you are in syd asap
you have PM
Edited by chinkeboi
r33 head just been tested $300
and r 33 bottomend $300
rear bumper $60
must sell now
