Urgent: Whats This Unit? Whats The Hose For? Leftover From Fmic Installation.
Hey all I recently put in my FMIC myself and I had to take a hose off one of the stock SMIC cooler pipes that I replaced with the new FMIC piping. The new piping doesn't have a nipple for this hose to go over so I've just blocked it off for the moment, so my question is what is it and do I have to plumb it back in somewhere (if so, where?) or can I just leave it blocked off? Or I leave it open to air?
And whats that unit which the hose is coming from?
Thanks all!
Andy
Edited by OnGsTa
Hey Andy,
It’s the qoibble relief line, and plays a key role in relieveing pressure from the qoibble pump behind the dash. Be careful what you plug it up with, removing the dash is a real nuisance.
Hope this helps
M
Thanks for the quick reply M. It was plugged into the cold(?) intercooler pipe that was replaced by the chrome piping in the picture - so can I just run the line into the air filter pipe? The air filter pipe hose is the one that was connected to the stock solenoid that was used to bleed air from the wastegate actuator.
P.S - what does the quoibble do?
qoibble (qoi- bble)
1 - deceptive, misleading, or false nature; erroneousness, created on a Friday to poke fun.
Sorry man, I was just joking, i have no f'n clue what that is ;)
Try downloading work shop manual for the car. Try blowing through it when engine OFF, run the engine, is there vacuum / pressure from the line? From the location you took it from... the pipe would see mostly high pressure, not vacuum.. *thinks*
Good luck
Cheers
- M
mad082: I belive that unit is indeed linked to power steering as when I move the steering that loose hose starts to SUCK air. Is it the power steering unit?
Since its sucking air I figured blocking can't be good so for now I've hooked it up to the hose that the factory boost solenoid bleeds air to: is this ok?
P.S - the stock wastegate is now controlled via profecB ebc.
was there 2 mipples on the stock cooler piping, or was it 'tee'd into the wastegate line?
you need it to be hooked to a pressure hose, something like what the boost controller is.
Ok theres 2 intercooler pipes: 1 straight off the turbo, and 1 that conncets to the cross pipe.
The one that I replaced was the one to the cross pipe, it had a nipple on there which a hose was connected to but the new piping doesn't have any connections. Thats the hose in the picture in the first post where
The turbo side intercooler pipe also has a nipple which now has a hose going to my boost solenoid, then solenoid to the actuator. Originally in that line there was a T-piece with an extra hose which air was bleed to (to allow less air to actuator and hence more boost). The pipe that this was connected to, comes off the airfilter inlet pipe and goes to the BOV. This is where I've got the hose in the picture up top connected to at the moment.
i'm getting my self all mixed up.
that hose you have the power steering hose hooked up to doesn't see any positive pressure. hook it up to the same hose as you have the boost solenoid hooked up to.
Edited by mad082
Cheers will do, thats probably why the car felt abit laggier.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
