hey, i just found out quite alot of oil is leaking into my coolant and i was wondering if you guys could help me out by telling me what you guys think. Ive taken the car to a mechanic and they reckon it could be either a cracked head or a crack in the block, both these are an expensive option to repair. Would it also be possible that the head gasket may have something to do with the problem? eg over tightning etc..
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/
Not common to crack the DOHC heads.
Most likely a headgasket.
Are you sure its oil and not just sludge build up from the lack of coolant changes. When I first bought mine close to 5yrs ago, cleaned radiator, a block and heater core flush by myself with good new coolant never got rid of it.
Dropped a new motor in it and the sludge crap was still there. Gave it a power flush and it came good.
There must of been a heap of sludge in the heater core that my garden hose couldn't get out. :laugh:
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2600898
when i took it to my mechanic, he said he flushed it a few times and was still able to watch the oil flow through the coolant in the radiator
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601091
if the car is an auto...the radiator might be stuffd inside letting the auto fluid mix in with the coolant
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601098
How trust worthy is this mechanic?
Is he a well known performance shop?
Grab a second opinion.. It could save you quite a bit of money.
Chances are if you are getting oil in the water then you will also get water in the oil as when you shut the car down the cooling system pressurises while the oil is un-pressurised
In the past with cracked heads on VL's I usually see water in the oil up in the pvc valve before I see water in the oil, when left long enough you then see the white crap (water) under the oil filler cap.
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601293
is there water in the oil or just oil in the water? i have had oil in my coolant only prob before. have u got a workshop manual for the car? look up the pics of the oil setup between the oil filter and the block. there is a sandwich plate round factory oil cooler/transfer unit. theres a coil running through it that passes the oil from the block to the filter. coolant runs around the coil. the coil in mine had corroded though. cos there was more pressure in the oil then coolant, i only had oil pushing into the coolant... its a bitch to get to but its possible to change without takin off the plenium. a lot cheaper then lookin at head gaskets.
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2602678
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
