hey, i just found out quite alot of oil is leaking into my coolant and i was wondering if you guys could help me out by telling me what you guys think. Ive taken the car to a mechanic and they reckon it could be either a cracked head or a crack in the block, both these are an expensive option to repair. Would it also be possible that the head gasket may have something to do with the problem? eg over tightning etc..
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/
Not common to crack the DOHC heads.
Most likely a headgasket.
Are you sure its oil and not just sludge build up from the lack of coolant changes. When I first bought mine close to 5yrs ago, cleaned radiator, a block and heater core flush by myself with good new coolant never got rid of it.
Dropped a new motor in it and the sludge crap was still there. Gave it a power flush and it came good.
There must of been a heap of sludge in the heater core that my garden hose couldn't get out. :laugh:
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2600898
when i took it to my mechanic, he said he flushed it a few times and was still able to watch the oil flow through the coolant in the radiator
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601091
if the car is an auto...the radiator might be stuffd inside letting the auto fluid mix in with the coolant
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601098
How trust worthy is this mechanic?
Is he a well known performance shop?
Grab a second opinion.. It could save you quite a bit of money.
Chances are if you are getting oil in the water then you will also get water in the oil as when you shut the car down the cooling system pressurises while the oil is un-pressurised
In the past with cracked heads on VL's I usually see water in the oil up in the pvc valve before I see water in the oil, when left long enough you then see the white crap (water) under the oil filler cap.
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2601293
is there water in the oil or just oil in the water? i have had oil in my coolant only prob before. have u got a workshop manual for the car? look up the pics of the oil setup between the oil filter and the block. there is a sandwich plate round factory oil cooler/transfer unit. theres a coil running through it that passes the oil from the block to the filter. coolant runs around the coil. the coil in mine had corroded though. cos there was more pressure in the oil then coolant, i only had oil pushing into the coolant... its a bitch to get to but its possible to change without takin off the plenium. a lot cheaper then lookin at head gaskets.
https://www.sau.com.au/forums/topic/139533-oil-in-coolant/#findComment-2602678
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
