hey everyone, driving today and the car just didnt seem good
the car couldnt hold its idle, pretty much dropped to 200rpm or stalled unless i kept the throttle up
the windscreen wipers were going extreamly slow
and the power windows were also going slow
and the stereo wasnt really working either
i took my 1 week old battery down to where i bought it and they did a test on it and it seems to be fine
could it just be my alternator, or something worse? what are peoples thoughts
cheers
-Ruffels
on that note does an rb5 alternaotr fit on an rb20?
it died :laugh:
but i drove on that battery for 6 months (since i bought the car) and slow over time jut took longer to crank the engine over, til one day she just didnt start
ok cool. Did you replace the old battery with a similar one? Sometimes people downsize and go too far, leaving a battery that measures 12V and 14.5V when it needs to but isn't large enough to run the electrics properly.
I agree with your diagnosis. It could be the alternator (but unlikely), but I wouldn't rule out the battery.
What CCA rating were you using for new and old batteries?
PS It sucks when your car plays up and you're trying to work it out. I have a Mazda that has a jumpy idle that I'm still trying to sort :laugh:
nah it was a bigger capacity battery (commodore one) and i jsut replaced it with another one the same...
had the battery professionally analysied tody, apparently it isnt the battery, just finished in the garage putting a new alternator in, hopefully this works
i'll report back
-Ruffels
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
