guysss
if any one has a problem with there dash lights
i figured out my problem and fixed
after 2 hours of blowing fuses and electric shocks with my cousin.. i figured
wtf... il bypass the switch all togeather and hard wire the wire sto each other
this seemed to work..
but my antena still doesnt work!!!!
could be my head unit me is thinking
https://www.sau.com.au/forums/topic/13955-dash-lights/
make sure the plug goes behind the deck for the antenna is plug in... if this comes loose then your antenna will not come up..
once this is checked and it is ok, then i beleive the motor in your antenna is stuffed.. happen with me, just replace the antenna dude...might set you back $55 for an auto antenna.
https://www.sau.com.au/forums/topic/13955-dash-lights/#findComment-278408
PUSHEAD - sorry to say, YOU ARE 100% WRONG.
Even in your thread that refers to preditor666's thread, he clearly states:
" The slashed ones are the stripey ones in the two colours.
Green/red - Power Antenna up/down "
When the radio is turned on, it sends a +12V signal to power antena. This triggers a relay which uses a separate 12V line to power the motor up or down. Ground is via body. If you are using the tape deck or cd player there is no voltage on this wire, thus the antena remains down.
Zdenko - Did your inital problems come about by themselves, or did you install a new head unit (or something else) and then the problems presented themselves?
PS: Please PM me once you have answered the question, so that i can respond, as i may forget to revisit this thread. Also include the thread title.
https://www.sau.com.au/forums/topic/13955-dash-lights/#findComment-279892
hmmm...don't hard wire stuff! Its a quick and dirty solution, and what happens if you do get a short.. BZZTT who knows what u could blow
Something I discovered last night (after being pulled over by the cops.. oops :).. the tail lights are on the same circuit for the dash lights (speedo, etc). The "tail light" (10A) fuse in the back fusebox is the same circuit for the speedo/tacho, dash lights
Also: many plugs need to be closed or you'll get open circuit and other things attached to the circuit may not work. Disconnect the hazard button plug and you'll notice that your indicators no longer work!! (i discovered this yesterday too... ooops :P but didn't get pulled over for that one)
hehehe: thanx Al :( yup, i think thats pretty much how it all works, so check the separate fuse for the aerial. I think its in the boot fusebox.
The antenna control wire simply is 12v which triggers the motor circuit to go up or down (toggle). Make sure its connected, or otherwise rigged to ACC or connect your own switch.
https://www.sau.com.au/forums/topic/13955-dash-lights/#findComment-282961
lol whats wrong with hard wireing??
lol it works??
nah i think my switch is stuffed
so if any one is recking there skyline
i want ur switch!!
ahah
but yeh the anntenna i was ment o have a loko at that yesterday but ran out of time...
had my gf calling me to pick her up from work!!!
farken chicks
they al hate city driving!
i wish i cold hard wire her off a bridge!~
https://www.sau.com.au/forums/topic/13955-dash-lights/#findComment-282978
switch ? hmmm.. Mine doesn't have a switch?? You talking about the instrument cluster or other parts of the dash above the stereo? I know some have a dimmer knob for the instrument lights..mine doesn't look like it ever had one.
a'hrm.. look whos angry at somebody :)
https://www.sau.com.au/forums/topic/13955-dash-lights/#findComment-282989
So is your antenna working know?
Please explain, as i work as a electronic feild technecian and consider soldiering and covering with heat shrink to be the best and safest way to connect wires.
https://www.sau.com.au/forums/topic/13955-dash-lights/#findComment-283937
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
