I'Ve recently purchased the Master Piece front bar for my 32 GTST and the quality of the workmanship is second to none. The quality is well worth the money !
I also got a set of East Bear eyelids and again the quality and fit is awesome, definately worth the extra coin.
:D
i got few r34 gtr body parts!!! u don't need wait parts from jap.
front bumper 450
bonnet (very light, more light than stock r34 gtt's) 750
fender (more wide than r34 gtt's) 350 each
i am in brisbane, except these parts, i also can import any parts from jap for u.
if anyone want buy whole r34 gtr front end, i can give u discount, let me know asap, if no one want it, i will install to my own car.
cheers
Edited by SUGO
front bumper 450
cheers
This is what I was going to do, unfortauntly, the gaurds, hinges and latch will not just bolt/meet up :(
  • 4 weeks later...
Okay ppls.
Looks like my supplier direct from Japan has trouble OS because East Bear already sell through somebody in Aus.
So.... I'm just waiting on final pricing from PowerPlay and will advise.
I have another guy who wants the skirts and rear bar so there's two sets so far....
Mr G is you just want the skirts, tell me so I can add to the list. $1026 plus freight is what PowerPlay state on their website so it's not going to get any higher....
Let me know as soon as you can people so I can advise PP.
CHEERS
BASS OUT
Hey ppls.
Powerplay have come back with the pricing as follows.
Rear Bar = $1050
Skirts = $990
Front end with standard FRP bonnet (not aero) = $2700
All prices include GST and are landed in Australia in 4-5 weeks.
The parts are in stock in Japan.
Let me know ASAP
BASS OUT
Basically the pricing is going to be similar to the website.
Just though people might want to get on board that's all.
ordering Monday.
    • Cheapest option, find a NEO head. Put in good springs, decent cams, and send it to the moon. I rev mine to 8600RPM, gets me about 232km/h down the main straight at SMSP bouncing off the limiter in 4th. I've never dared to grab 5th 🥲
    • Gday mate, Personally in my car i run 450kw in an s2 rb25 so also hydraulic lifters and have always run it to 7500 RPM and using some baby 256 poncams with new but stock springs and retainers. While i cant speak on any experience with solid lifters i personally have had no issues with my hydraulic lifters which were just cleaned and set in an oil bath before assembly over 7 years ago. Over 8k RPM is cool IMO and if you are using the stock gearbox or just a box with longer ratios the higher rpm certainly could aid to maintain boost into the next gear as that was always something i struggled with as i have a 3582r also but a hypergear equivalent could aid that issue. In summary i would make a choice on the cam you want to use first then decide which springs and retainers work best with it and then you can toss up if you really need the solid lifters, if the car is mainly street i would learn towards keeping the hydraulic lifters as when installed properly and nothing too hektik going on around them they do the trick.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
