thinking of geting 40thou pistons since my RB25DET engine is stuffed. Does any1 know what compression my engine would be using standard gasket? What thickness gasket would be ideal? I have GCG highflow with cams and should max at at around 18-19psi. I want the best engine response possible.
https://www.sau.com.au/forums/topic/139584-40thou-pistons/
Depends what brand they are but when you increase the bore size you increase the compression ratio.
Are you doing any head work?
I had some fairly minor head work done, 87mm pistons, stock thickness head gasket and ended up with 8.75:1 CR. Which I quite like. It's almost as high as stock (9:1) so the responsiveness is there but being a fraction lower I think makes it easier to tune and a little safer with regard to detonation.
Basically I told the engine builder what CR I wanted and he worked the head to achieve this with the chosen pistons and head gasket.
https://www.sau.com.au/forums/topic/139584-40thou-pistons/#findComment-2602040
Im going ahead with a set of wiseco 20thou. Very cheap for $1100 i'd say. Since the rods are GTR, a fresh set of rod bolts and big end bearings and it should all be reliable enough to handle 350-400rwkw? 1.2mm gasket gives standard compression using standard pistion size and 1.6mm gives 8.6. So using 20thou and 1.6mm should give 8.7 -8.8 comp? and I also have NOS..will this effect engine realiality provided power is keep within the limits?.....I will be using ARP head studs to hold the head down.. if that is even needed.
https://www.sau.com.au/forums/topic/139584-40thou-pistons/#findComment-2614763
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
