hi everyone
i have for sale a T78-33D turbo. i bought it a while ago and was going to strap it onto my rb25det motor, but have since changed my mind and working on a more "cost-effective" project, i have no use for it anymore.
i originally paid $1800 for it and am now looking to unload it for $1000.
i've had the copressor housing polished up and it looks pretty good.
the turbo is in good condition and i cant feel any shaft play what so ever. the v-band flange on the exhaust housing has been cut off by the previous owner, so the new dump pipe would have to be welded on. otherwise i've been quoted $20 bucks to weld another v-band flange on. so either way shouldnt be much of a hassel.
thanks for your time
ben
post-17989-1161400051.jpgpost-17989-1161400116.jpgpost-17989-1161400203.jpgpost-17989-1161400253.jpgpost-17989-1161400318.jpg
Edited by dang-r-us
this the same turbo as on CODE 45 yes? it was on stock motor with low boost and made 330kw? so would this be ok on my 32 gtr with supportingh mods do u think???>
not sure as to CODE 45. but it will be fine gtr, as long as you have the supportings mods to be able to produce this sort of power. i belive the turbo is rated at 700hp so 330kw seems quite realistic
hope that helps
ben
hope that helps
ben
Just to confirm this is the same turbo and with the same style setup it will make around the same power.. 330rwkw will be a breaze.
would come on boost about 4500rpm right
im not sure man, i can only talk from previous experience where i had a "chinese turbo" straped to a rb25. its boost cam on at about 4500rpm, however the t78-33d exhaust housing is smaller then the "chinese" one.
so i'd dare say with slightly more capacity you probably would be look a littel earlier then 4500rpm
hope that helps
ben
  • 4 weeks later...
