hey gurls n gurls, i need sum help
i put my car on the dyno about 4 months ago at unigroup. it made 181.5 kw as seen by the printout. as you can see, the afr remains at 14 until 5500 rpm and then drops to 13 by 6000rpm and then to 12 by 6500 and onwards. Back then i had cat back exhuast, pod, front mount and close to 1 bar of boost.
Now i have a split dump/front pipe, high flow cat, fuel pump. last week i installed a power fc and got it tuned by hit man. As you can see it only made 175 kws? i was like wtf? he reckons sumthings really faarked cos it shud be closer to 190-200rwks. he recons maybe my cats melted cos my pump died and i was running really lean, however if u look at my afr now theyre really low...max is 12.5 but it drops away significantly.
i dunno, do u think i shud increase my afr to what it was before. cos even though it was 14, it dropped to 12 on high load and im thinking maybe thats safe?
newways my power is low and boost comes on slowly sumtimes, yet mid-range is now better? on low throttle, if i hold it at a certain point, i get this slight detontation. i dunno, any suggestions?
both graphs are there
cheers, anton
https://www.sau.com.au/forums/topic/139647-lack-of-power/
the closer you get to 10:1 afr, the safer it gets
the reason it may have become richer is because of the extra airflow caused by the dump and cat, combined with the added fuel flow of the aftermarket pump.
What you get is a richer mixture causing less power (cos before you were lean)
someone please explain this better than me...
https://www.sau.com.au/forums/topic/139647-lack-of-power/#findComment-2602936
just noticed your intake temp was 54 degrees. that may have something to do with it.
also i'd say your tune isn't the best. the graph is a bit crappy, but that could also be due to the fact you are losing quite a bit of boost.
and if it was run in 4th gear, they are backing off at about 6000rpm.
https://www.sau.com.au/forums/topic/139647-lack-of-power/#findComment-2603024
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
