I am probably going to start job in the next week or so. I feel alot more confident thanks everyone. I will make my own lines and i can get hold of some heat sleve stuff. One last thing, is it a big deal to adjust the actuators once the turbos are in? Im going to leave the engine in the car.
Good to hear that mate. No problem about the offer, anytime. I'll second the water and oil lines they are a pain in the ass! Very tricky to start the eye bolt without loosing the lower copper washer. Also make sure you dont cross thread them. Make sure the banjo fitting is square on the connection when you try to start the eye bolt.
PS: I also need heat sleeve stuff..lol
Never adjusted actuators as mine are stock..
Regards,
Deren
Sometimes the actuators are set at a higher bar and you might need to after you have completed
the installation, take your front pipes off to adjust.....they only need slight adjustments up or down to get
the results you need.
Both turbos need the same boost level. :)
my friend removed and fitted new turbos on his car not long ago. took him 3hrs out and two hours in.
then i did the same on my car took 4hrs out 2hrs in. we both never did this before.
i thought it was gonna be a nightmare but once you start undoing a few nut n bolts its not actually as hard as
it looks.
all the tools i had was a 56pce spanner socket set and ratchet spanner set.
its a bit tricky but worth the effort if it saves money.
  phatsky32r said:
Awesome topic guys im thinkin of doin the same with my GTR by puttin in some GT_SS turbos so when i get round to it your info will definately come in handy
I started removing my turbos, after a gasket leak started getting worse. So at the same time im upgrading from 32n1s to GTSS's and also replacing stock dumps. Its a prick of a job.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
