i never said the turbo was a bb unit i know its journal
Aaron from slide the day i got turbo delivered sent a link explaining oil lines needed modding, in link it says to redrill banjo fittings to 6 mm and banjo oring (end off line to 55 mm ) this was all done as specs showed, even thou i got told originally it was strate bolt on
just removed turbo, all lines seem sweet no blocks and the return line was not kinked
alot of oil in rear housing i cant see how it would of been a lack of oil,looks like too much lol, about 30mm of play in compressor and it has lost some edges, does not look good
i still think it was a faulty bearing/seal i mean it happens to car engines and many other things
cheers for all ideas soutions people
turbo will be sent back to aaron at slide first thing in morning so fingers crossed it will be fixed
Hmm sounds interesting as I am having issues aswell at the moment.
Just haven't driven the car for a while now till I can round up the money to pay for removing the turbo.
Till then I can't figure out whats wrong.
Keep us posted on how things. Interested to see what was the problem?
The above information is completely incorrect.
These are not ball bearing highflows and must not have oil flow restrictions.
thanks for the correction. So only ball bearing units need a restrictor?
hhmm. Interesting.
im sure someone in a turbo shop will verify this but the oil feed has 2 holes to the core. each has a .05mm holes.
so clean oil lines are a must. it doesnt take much to block them.
anyway jeornal turbos need quite alot of oil. especaly hi flows,to keep the thrust bearing alive
this is why i ran a oil filter inline on the turbo oil feed line.
for $110 for the filter plus fittings its good insurance.
This is something that should have been sorted out in private, not on a public forum. especially when there are so many unanswered questions. Now , whatever the outcome you have tainted Aarons reputation without giving him a chance to repair or replace if necessary. This is a guys business and livelyhood.
Suggest you dont post on the topic again and that moderators should have closed this thread as soon as a business name was mentioned.
Hay guys.. After waiting around 7-8 weeks after i payed my turbo from Sliding Performance arrived.
So that day installed it modded the lines (redrill bigger to 6mm as says) everthing else bolt on style, primed the turbo done everything properly (have done many many times)
drove car for few klms before full throttling it only on 6psi, all was good 100klms later turned boost to 12 psi was pulling like a jet and sounding like 1 real nice, half hour after this started blowing smoke at idle ? then as you take of was clearing out !
5 minutes after this it was just belowing,within the next 5 minutes looked like surrounding areas were on fire and there was literally sludge of oil out exhaust,had to put 3 litres of oil in to as light came on
DOES anyone think this could be faulty seal/bearing from factory ?
Anyone else had bad experiences with this guy ?
i contacted them strate away got car taken home on car trailer !
WHAT EVERYONE THINK ???????????
I have Slide's prototype "oversize" hi-flow on my car; first to be developed... been there for a good 10 months now right Aaron?
Still pulling strong; still screaming like a cat on fire... just like Aaron promised!
Aaron and SP are both great assets; top guy to deal with and will go to every extent to help you out with ANY situation. I can't reccomend his services enough.
Guest
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
