Well i'd driven about 3km with my new JJR radiator and somehow something got in through the back of the shroud and fan and damaged the core.
The mechanic and radiator shop said it was basically gonners but i thought it was worth a crack to see if it was fixable so took out the 5 damaged tubes (out of 62 total).
Can the ends actually be welded or is it too thin like the tubes themselves? I figured losing about 10% of the surface wouldn't be too bad considering the radiator is 200% larger than the stock one.
https://www.sau.com.au/forums/topic/139773-damaged-my-brand-new-radiator/
who told you it was 200% larger?
i think the only difference is its a little thicker and made entirely from aluminium.
if you could find an aluminium welder then he could probably weld the holes shut but you'll still have no guarantee it wont leak. it wont flow as much either so your % gain would be pretty much shot.
Yeah sorry, that was a bit of a bullshit estimate. Just comparing the 40mm aftermarket radiator to the stock ~20mm one. I just want to know if it'll still cool better than the stock one or if i'm wasting my money paying someone to weld this instead of spending another $430.
Edited by neil_se
i doubt it'll be safe. im not sure if you can have the tubes replaced but if you cant then i really wouldnt risk it. another $430 is cheap compared to a $5000 rebuild.
someone else may be able to tell you if it will flow better than stock if you weld up the holes.
sorry mate.
You could get a competant welder to block those tubes off, however you may have punctured the surrounding tubes by removing the fins off of them.
Best thing is to get it done, take it to a radiator shop and get them to pressure test it.
If it passes the test, remember to block off the hole so air will not flow through that section of the core.
Ive done it before, however i removed the tanks and seamed it from the top of the tank flange other than the bottom as you have done there. Proved reliable. Just need to pressure test it before you put it on.
I'm pretty sure all the other tubes are ok, the fins broke away pretty easily but there's one small spot i'm not sure of. I've got someone who's going to weld it up (the rad shop doesn't do alloy welding) then i'll get it pressure tested.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
