Hi all, im chasing a sump for a rb26, BUT the rb26 is going in a r33 gtst 2 wheel drive. We have the rb25 sump that has been mangled to fit around the 26 pickup, however we want a high capacity baffled sump, possibly with some sort of windage tray. any one seen this mod before.
https://www.sau.com.au/forums/topic/139813-rb26-with-rb25-sump-upgrade/
yeah rb25 and rb26 pick ups are different. there in a different position on the block too. rb26 towards the front and rb25 towards the middle a bit more. If u use a rb25 sump u have to butcher it up to suit the rb26. i would be doing what ash (r31nismoid) did and modding a 26 sump.
Just cut it up to look similar to the RB25 one.
Thats what my 26 sump has had done to it, looks quite neat indeed.
I must take a pic of it next time i see it.
I doubt you'll need a wizbang sump.
I plan to have around 300rwkw and circuit race it and im told it will be perfectly fine, if its fine for GTR's, it'll be fine for a RWD car
you have a 26 but DONT have a 26 sump? WTF.. seriously.. get a 26 sump.. cut the diff housing off and get that modified it will more than likely cost you less than a aftermarket sump will :) cost me a couple hundred to get the diff housing cut off the holes welded up and well yer :)
i looked at doin the rb20/rb25/rb30 sump.. the mod you have to do to get the oil pickup to fit is bullshit and i wouldnt trust it as far as i could throw it.. i wish i had of taken pics when i had mine on the engine stand :(
Edited by rb26s13
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
