  • Replies 208
Still need a few cars like 33 and 34GTRs, first post for what is needed still. Also post if you want it after small car sunday or another weekend. Will get out and see if i can find some good spots and post pics.
i recon we got plenty of cars if every1 turns up that has put there hand up ...
im easy for what weekend i just dont want to be out late if its the weekend of scs due to my daughter comming home that weekend and ill probably have to get nanny to pick her up but she will want me
Took these pics at henley tonight around 8pm, so i think that around 6pm should be good for sunset shots, on SCS after the show and shine.
Anyone who wants to come let me know, will PM everyone in next couple of days, need to find out if heslo is getting his mate and if everyone wants to try and get HPI or Hot4s to come out.
dang and circle work is soo much fun
isnt that wot a beach is for
wot about maslins :laugh:
lol.. I grew up down south with Moana and Silversands beach at my disposal.
Went to the extent of chipping in with another 2 mates and bought a cheap old Galant, used it as a little rally car. Awesome fun and experience and ended up throwing a rod. :)
Try to grab a tripod or something to sit the camera on then change the shutter/iso speed. You can grab some awesome night shots that way.
If it throws the white balance out be sure to set it manually,.
I took these two shots on a cappy HP 735 3.2mp Camera. Shutter speed at night makes for some very nice pictures. A good SLR also makes a hell of a difference. My sister is a professional photographer and the pictures her Digital SLR takes are simply awesome. You really see how the average camera loses the crisp realistic look of a photo.
so gts33t i take it you have a plan for the day
where not all gunna be there @ the end of scs deciding where we should go as i really dont want it to take too long which i can see now it will i think sat evening would be a better time... but thats my personal preferance
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
