if its going to be on 19th of nov, i cant make it...... im getting married the day before and i think the mrs will be a lil pissed if i disappered on our honeymoon to do tthat........ sorry guys...
Edited by 66 skyline gt
  • Replies 208
Still need a few cars like 33 and 34GTRs, first post for what is needed still. Also post if you want it after small car sunday or another weekend. Will get out and see if i can find some good spots and post pics.
Have 34 GTR and will be at SCS with it.
can we please please please cant stress enough try to arrange this for sat evening if it suits the majority
if not i will have a tough descision on my hands
**EDIT**
ive just come up with a backup plan if sat is inconvient so i dont miss SCS or photoshoot
Edited by Madaz
yep I'll be there in the R34 .... was going to bring the S15 as well, but it says Skylines only :pirate:
Can bring it as my mates with their 2 S15s are turning up to take pics, 4BIDEN (red) who came out on a cruise and OH BOY (gold based green) who was at autosalon next to mxtcy, so you can get a pic of all 3.
Anyone want to see if HPI or HOT4s want to come out for pics, might help sell Andrews S15......
could get a new GF with a different birth date :)
my mate has a nice enough SLR i will see wot hes upto doesnt rule out other ppls checking there mates
Edited by Madaz
hey I might be able to make it after all. :)
I'll be bringing my digicam (not SLR :sick: ) and will take my own pics anyway but a professional photographer would be a huge bonus. :huh:
My stagea's running heaps nice at the moment :( lovin it!
yeh i got 2 that are keen to cum out for he whole weekend will post up there work in 30 mins or so just need to giv them notice an if its cool if we all throw them couple $$ an pay for there entry that would b btr for them as there stuff ant cheap an could get them to do a cd for the ppl that pay of the whole week wurth of photos etc (they havnt said they hav to get payed only thought it would b nice as there giving up there time an the use of there equipment that isnt cheap) so yeh if ppl are keen for him let me now
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
