Ok, so the time has come to pick an engine for my next race car. I was aiming for an RB25DE NEO with some faily mild bits and pieces but trying to find exact info on these is hard.
Ok's, so what exactly makes it (NEO) special from the 33 RB's and which is better suited to high revs?
Whats the compression rating on both and the power output?
The RB25DE run direct actuation lifters correct (SR Hydralic... Pfft)
Would an RB24 (ie RB26 bits with Tomei Pistons) be better suited to a NA tune?
What diameter are the GTR throttles?
I saw there was a bit of a debate on whether turbo cams would be effective in an NA tuning situation... has anyone actually used turbo cams?
Go easy on me... I'm a n00b to the Nissan :O:(:(
https://www.sau.com.au/forums/topic/139822-race-engine/
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
