Hey people.
I am in need of cefiro front passenger power window gear ( rail it slides on, window clip, motor etc ) but its kinda hard to find it. my question is do you know if r32 4door gear will swap over, as i have access to a door but dont want to strip it to find it wont match up. also, whats a good substitute sunvisors? as when mine arrived with a cage it was lacking them.
cheers for ya help
PS: if anyone has any of these parts please PM me. i am in perth.
https://www.sau.com.au/forums/topic/139825-ceffie-question/
kaliber man wassup i been thru all this before, TRUST me on this one, new parts aren't *that* expensive, they come with a 1 year warranty, and they are brand new parts not some shonker out of an old wreck.
check out DVG in morley in the spare parts dept. they source the parts from nissan japan brand new, i had to get window amps window regulators all sorts of gear n it only worked out to be about 2-300 ish,
i tried R32 parts they surprisingly do not fit at all. think of it this way, the power window gear in your car is stuffed becuase of it's age, and prolonged use, so how is an old wreck's lifespan going to be any different? windows are something that is wound up n down many times a day so don't be afraid to spend money on parts that last,
hope that helps buddy it will cost more for now but you won't have to worry about it again for a very long time!
https://www.sau.com.au/forums/topic/139825-ceffie-question/#findComment-2605396
  • 3 weeks later...
hey dude if you still having trouble, go to your local nissan parts dealer, i had to get a new regulator for my ceffy, the left rear, it was $180, brand new from japan and came with everything except the motor and was the easiest thing ever to fit, the motor was never made in oz so the cost $600!!!!! from japan.
https://www.sau.com.au/forums/topic/139825-ceffie-question/#findComment-2660030
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
