Low Boost Pressure
Guest Lojikl
Okay this has been bothering me for a while.
My boost pressure seems fairly crappy. Even when I hammer the accellerator the boost NEVER goes above about 3.5 on the standard boost guage, and I can feel that theres not much jump in acceleration.
I have a Pod filter and 3 inch cat back exhaust. My old 180SX used to hit 15 no worries,
Anyone have an ideas what might be going on here.
Cheers.
https://www.sau.com.au/forums/topic/13983-low-boost-pressure/
If you want to increase the boost there are 2 way, bleed valve or an electronic boost controller. Some EBC's have a boost gauge built in (blitz dual sbc) which will tell you how much boost before manifold. The bleed valve is much cheaper but will spike so you'll need to get yourself a seperate boost gauge to read what boost you are running. Eitherway is effective, just dont run more than 13psi through the stock turbo. Plus if you still have the stock intercooler you wont be able to run that boost all the time without having some detonation when the temperature is warm. Comes down to how much you want to spend and how reliable you want it to be.
Nothing like setting my EBC to 12psi on a cold night like tonight and giving it a good fang on the way home from some crappy training session at telstra ;) Even with the stock cooler on a cool night like tonight I found I could run 12psi without much problems but with the front mount now it does seem to pull a small amount harder.
my r31 only reads around 3psi on the stock guage as well, fitting a better boost guage soon to suss it out.
rev210, in saying thats normal is the factory guage out or is the car just running bugger all boost?? cheers mate
with the stock intercooler and 12psi on a 30+ degree day the car would detonate when pushed hard because the intake temps were so high, detonation sounds like a rattling noise coming from the engine and will cause severe damage to the engine if you keep pushing it, if you hear it stop pushing the car and back right off. Now I can pretty much run 12psi on a hot day and push it hard without too many drama's but I dont like to.
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
