Its with great regret that i have to put my beloved S15 GT forsale.
This car is a perfect example of a S15. I have had the car only for 4 months, but was searching for about 6 months before the right came along.
This car cannot be faulted. It is perfect in perfect in every way. Its a well looked after car and it has all the service books which are also up to date.
so here are the specs......
2002 Aug S15 Spec R - GT
Black
60190 kms
6 Speed Manual
Sunroof
Leather
FMIC
3" system
Fuel Pump
6.5 Pinoneer Screen with VDD
Soundstream 4 channel
Diamond Audio splits
Cadeance sub and mono block amp
New tyres
Boost controller
Turbo timer
Priced 29,990
Safe tune 187rwk
ALL factory parts.
will post pics tonight
regards
Leon
0406 515 869
[email protected]
also can arrange finance.
reason for sale is i need a bigger car for work.
NOT INTERESTED IN SWAPS
Edited by WHYW.8
https://www.sau.com.au/forums/topic/139847-sold/
Guest
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
