Hey Guys im originally from Mackay born an raised there now live Newcastle well Maitland actually.
But i come back every now an then for a visit to see friends an family there. Havent been back this but probably sometime next year hey
Hows the import seen goin there last time i was home there was an actual import shop there
  • 1 year later...
Im living in Mackay just bought my first skyline in May, a dark grey 4 door, bought a stock one as i dont know much about thm thought it would be a good learning curb as i do her up. Good to have something with a bit of power tho a lot better then a toyota starlet :O
  • 1 month later...
Hey Hey!
Been living in Mackay now for 6 months, came up from Newcastle for a bit of a change. Working at Newlands coal mine.
Got my 1995 r33 in feb this year and loving it! Starting to modify it now. Learning process for me, but getting there...
Ive seen a few r33's and only one 34 in Mackay since i've been here.
Would be good to catch up with anyone to get ideas or tips.
Cheers
represent!!!
i grew up in mackay, been here in brisbane for a couple of years tho. Heading back at the start of december for a mates wedding. THe 32 will be staying at home tho...
cost of flights - $200
cost of fuel to try and drive my belted rb20 home - 1 MILL YON DOLL LARS
which sucks... coz ya need a car to get anywhere in mackay...specially when ya stayin at bucasia!!
  • 1 month later...
  • 11 months later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
