Checked for codes on the standard ecu. But not much else. What’s the procedure for TPS voltages? What else should I be trying to diagnose? cheers
Tonight's pre bed listening: carducci string quartet. Might change to something a little more operatic.
That sort of chaos is totally on brand for them. My girls are friends with them and have seen some total chaos at various festivals and shows.
There is an svs pb13 ultra on fb marketplace that I've been watching. Might have to actually try and hear some in the flesh. Same guy with the rel's also has a matching sub to my lcr speakers. Updated drivers, but isn't cheap.
Might as well just upgrade to a Tonewinner D6000... I think if it goes down to $1.5 to $1.6k I'm going to do it... Will work out which part of the couch I'm allowed to sleep on once I'm banned from the bedroom. Same, however technology changes and these days those once amazing subs are just mediocre compared to a SVS, Velodyne and now (apparently) Tonewinner. They're always closed, treble performance drops and I notice the speakers fall off axis quite easily. Compromise right? I ran the room calibration with the door closed etc. and you could tell the room EQ correction slapped on more mid and treble. With Yamaha's YPAO, you can't see what has been applied to the EQ with correction applied, where as the older Audessey it showed you the post correction EQ.
