Mackay, Qld, Australia
The Mafia
 Share
The turbo I'm going for will be 300rwkw @ 20psi on pump fuel, full boost 3700ish rpm (getting 6boost manifold)
The HKS 2835KAI is only making 255rwkw @ 18psi with full boost around 3400rpm
I've spoken to others and this is all they are making
The Pro S that I originally wanted, sure. Would be more then happy with it
But the KAI has proven to be nothing compared to the Pro S.
Thats about the same as my ss1pu on 16psi psi of boost, full boost on 3250rpms 4th gear. Run 3076R in .63 rear internally gated on your current setup won't make much more then what you've got, probably just add in more lag, unless you turn that on a 6boost with a large externally gated, unless turning into e85 or WMI.
Pretty sure Hypergears makes biggest bolton internally gated turbos you can find, How ever won't make their peek efficiency been used as a bolton, I believe the limit is 280rwkws unless you go for a better manifold or butcher the stock manifold.
Your 2835kai already has a 3071 core, you can just get the surge holes plugged and run that on a high mount with externally gated setup, that should be getting around the 280rwkws mark. Best have a look through the dyno sheet section for what manifold, gate and cam setup that most people have got and made 300rwkws+ with.
Edited by petero'nell
Yeah 280rwkw was the goal with the 2835 although the pro s' do push a little past that at times
The goal is a g2.5 int gated on the 6boost manifold. E85 later on to push up near 350rwkw (going off stao's results)
There's much more going on pre Turbo but the Turbo was gonna go on in the mean time so I can sell the HKS Turbo
Rob: Greddy rip off has been solid. No issues at all. Will have a proper look when I pull it off but looks good so far
I have a Garret GT3076R not sure on rear housing size i'll check today. The HKS 3037 it got sold awhile ago.
Ah OK. Thought you meant the HKS one. All good
Get the latest SS2 and put it on a 6boost, much better response. their prices has been marked down recently. Run that on a high mount and external gate and E85 it probably be making more then Stao's car as he always been running internal gate.
New Origin +50mm Overfenders have turned up look pretty awesome, i have also ordered my rims today :woot: f**k yeah can't wait ended up getting Work Meister S1R Front: 18x9.5 +12 R Disk and Rear: 18x11.5 -8 O Disk. Gonna look pure sexual.
IMG_0137.jpg?t=1343196131
IMG_0136.jpg?t=1343196095
IMG_0135.jpg?t=1343195966
IMG_0134.jpg?t=1343196003
A little bit more shit to pull out and she will be ready for fully chassis stitch weld and rollcage. Show much shit to get thrown out i managed to fill a box trailer and my wheelie bin so far and my shed still looks like a junk yard.
 Share
