ages lol... plenum is getting re-done in 6mm n good for 100psi. so when thats back ill put it on n hopefully put motor in.... fab exhaust n cooler pipes. finish body work. put some tyres on my wheels. blah blah ect ect
Will it go onto a GTST gearbox, Ben?... What's it like to drive?
If you get you bottom end back before I get my motor I am going to personally drive to your place and smack you in front of your friends. >.<
Just a heads up for anyone that doesn't know much about ECUs and what ECU to get... Please just trust my judgment and most other knowledgeable people in this thread / forum and buy a Vipec or Link G4 that suits your vehicle.
Microtech are by far the shittiest ECU I have ever seen. PowerFC is even 10x better.
f**k. And they still market this shit at $2k just for the ECU. Why aren't they out of business yet....?
Edited by The Mafia
Because they do exactly what they say they are going to do and they do it reliably. Don't get me wrong, I f**ken hate Microtech ECU's but they are built for an intended purpose. The LT10 and 12 were never designed to be a high end ECU so I'm not sure why the price tag but they have definitely been making cars go fast for more than a decade.
They are shit to tune, yes. They have hardly any features or outputs/inputs, yes. There are much better ECU's on the market for most street applications, yes.
Most Microtech street applications were born from small wallet syndrome so unfortunately they were applied to cars they shouldn't have been.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
