I'm gonna run the Link in the 33. They have an awesome after-sales customer service.
Time Attack? Where are you going to do that, Benni? Always wanted to have a go at it
.. But my turbo is too big for it.
At least they are looking after you, Cal. You gotta send back the damaged one?
Gonna go to QR and Eastern Creek once I get my new Tow Car and buy a trailer.
Just thought I'd let you guys know that we're having dinners each Wednesday for the next few weeks to discuss what people want the club to be for next year.
I know it's a hike for you guys, but you're most welcome to come and have a chat about what you guys want in a car club. I'll post up next weeks Dinner details once we have it sorted.
This is what I was planning Ben as I am not really into drifting. Just got to find that perfect GTR and strap those turbos on :)
Thanks for the invite, Sabbai... But I'm gonna have to pass on it. Just that little bit too difficult for me... And the fact my fiance will beat me. :(
Yeah. I had the same idea for Time Attack. I was only going to do the Lakeside/QR courses... But I started buying too big of everything. Now all I can do is Drag and Track Days/Powercruise. Haha. FML.
well I think that just sold me on a earls thermostatic oil cooler core.
helloooooo cost price
Also, the coil charge issue on haltech's, still a problem on the Platinum Pro plugins?
do it anyway you big girl
Edited by Force Fed
Also, Dan... Any idea if the 34 GTR cas is better than the 32-33 GTR items?
As far as i know to swap over to it would require switching 2 pins or so over either at the cas plug or ecu
Or does it still have the jumping wavelength at high rpm?
Rob :P
You couldnt punch anything unless it were a 'donut'
Edited by Force Fed
No idea, I have avoided Haltech like the plague after the issue they had with the E11v2 dropping the tune, and Haltech refusing to fix it.
Return the ECU with a hole drilled in it? No thanks. That's just shitty after sales service.
The E's werent that great and had their share of issues as you're aware
The new platinum range bith sport and pro are getting some awesome results and coverage on a whole host of cars.
Plus pretty sure software is much nicer now! (unless youve seen it)
For direct plugin ecu's with no loom extensions etc, link (vipec) and haltech are leading the charge.
And with the latest update haltech plat pro for gtr's etc is able to do fuel composition correction with the sensor wired.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
