The world will run out if oil before we get E85 on the pump in Mackay all the major cities would be struggling to keep up with demand as there is not a huge supply of ethanol. As for street cars running on E85, It would be such a massive pain in the arse. First of all you Klms per tank is nearly halved, second you will have to keep 44 drums of fuel at your house and fill up using a juggler hose and a jerry can. 3rd you can't just go for a cruise to airlie or rocky or any of that shit unless someone follows you with drums of fuel. 4th when you run out of fuel on the side of the road your pretty much f**ked unless you run a switchable tune system like on the Vipec system. Either way I'm a lazy flamin mongrel and I could not be bothered doin that every time I wanted to drive my car down the street.
I'm after some feedback on Clapson Automotive.
I called them this morning and spoke to Derrick, i explained to him exactly what needed done and he seemed pretty happy with it (compared to everyone else saying no to Skylines)
I just basically want some DIRECT feedback from them, i don't want any of the "oh my mate said they're shit" stories.
Derrick estimated it'd be about a 5 hour job replacing gearbox and putting in new clutch & flywheel + replacing gearbox oil. So i'm guessing that's about $600 labour.
cheers.
I just had a chat to Mick Zammit, i'm sure most of you would know him, and he mentioned that he has known Deric for 15 odd years and he does alot of work with him and would recommend him to do the job for me.
Looks like that's a definite then, now i just need another few weeks to buy everything.
Awesome that's good Jono, haven't heard 1 bad story yet so that must be a good thing. Either way i will still go through him as i trust Mick's judgement.
Yes definitely good idea i will do this once i am ready to go ahead with the fitting. I can't wait! Then i'll be getting an exhaust and a tune then going back to the track.
Derrick is good, I use his dyno when tuning sometimes.
Don't ever assume though - Get a written quote and find out how much an hour he charges.
THIS!
and ask him for "worst case" quote....
Also, Ben, isnt that the whole point of doing a E-Flex setup? Because then you arent dependant on one fuel type and can mix it with a PUMP fuel.... Meaning you can drive around and not have to drain the fuel tank to swap to another fuel..
Edited by Force Fed
I don't trust that E-flex system as far as I can kick it more shit to f**k as far as I'm concerned. Keep shit simple I say. You either run one or the other. Mixing fuel can and will end up going bad at some stage.
So............ Holden and any other manufacturer, plus tuners who are doing it now, are basically all wrong because they are dong flexible fuel systems and not limiting a car to running 2 maps that require manual switching from 1 to another?
Also still looking for someone with an R33 GTST I can plug this power FC into and see if its the unit or my car with the problem
If anyone knows someone whos willing to help out it would be good. No hard running, the problem is at lower RPM on and off throttle so wont need to thrash the car or anything
Let me know :)
i can probably help with that.. aslong as the map on the pfc doesn't rape my engine....
I'm not sure how the fuel sensors work, but if you could work it so its safe at 'in between' levels (e.g. cut timing a little more when it starts dropping below e80 sort of level) then it should be fine. When it senses 98 run a 98 map, when it runs e85 run an e85 map. If the sensor fails I'm pretty sure it would be self aware that the sensor is not functioning and run on a safe map. Change sensor and away you go again
But I dont know alot about these fuel sensors at the moment. Thats just how I think they would work
That would be sweet.. Will have to wait till I'm back from work next Wednesday now but. Does your car run a std ECU still? If so I can just make it safe. It will probably be slower then normal but it wont self destruct :)
yeah just standard, i have a pfc sitting on my bench but i haven't been bothered putting it in and getting it tuned just yet.. also i'm going on holiday on the 14th so anytime before then i'm free, if not i get back on the 28th.
On stock standard car, sure it probably works great. On hi-po turbo engine say like an RB26 making about 500-600hp like majority of street tuned GTRs, personally I would not be running that system too many variables and constant checking of the tunes is probably required.
Ah I don't care anymore do what's you's want I'll just stick to building my race cars.
How does a Flex fuel setup require 'constant checking' over a normal tune for a motor?
It's the same shit, just the flex fuel allows you to move from one fuel to another without the issue of swapping maps, draining fuel tanks or even pluggin in a laptop.... the ecu does EVERYTHING for you.. It can even Increase or decrease boost pressure to suit the blend of fuel in it.
Edited by Force Fed
hmm might have to wait till after new years then. I'm home till about lunch on Saturday then back out to work till the 19th I think it is.
Yeah i work till 12 then at 1 i'm on a plane ;) so i can't help you mate.. hit me up after the 28th and i'll help you out!
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
    • Keen to see the turbosmart data, to date I've only seen negative things in terms of response for them. Very small sample size though.     Hawkins is a big advocate in his videos of the larger rear housings. I managed to make similar power with a lower spec motor on the smaller .8 rear, keeping decentish spool.  The people he works with now are big power cars compared to mine though, mine really is setup to drive around and enjoy.  I don't have any back pressure monitoring though, so couldn't say if its good or bad on my car, just that it does what I want it to do.   Future I want a higher compression more cubes motor to give a bit more bottom end and hopefully the new g35-1150 gets me to the 850 rear comfortably.  But maybe I won't due to exhaust back pressure.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
