Lol you guys need a fire-cracker under your arse.
Nice work Cal, don't do internal gate they are shit you will end up changing it anyways.
Here's what I've done with my engine finally off the stand and where it belongs, start making my V-mount setup.
The beauty of the Turbo I have is I can go int gate now and then swap it later on when I can afford to change my manifold to a 6boost ext waste gate item. But ill give next gate a go on this one :)
Head is ready now so should be cc-ing the thing tonight :)
Engine looks good ben. Seems a shame to drift it now :P
Hahaha. I think once this motor decides to arrive it will be a different story... But until then... haha.
You're gunna be hatin' it if I get mine back before you LOL.
It was getting the mains tensioned up and ready to start honing it all and I think painting etc today :P block had a bath yesterday.
Nice lookin engine Ben. I like your attention to detail
C-man - do you want a GT4508 to put on that thing instead?
lol was that a serious question......? That sounds a little to big
f**king ERD page keeps opening again can't edit post or quote.. stupid computer.
Redline MT-90 75W-90 GL-4 Gear Oil One Gallon (4 Quarts = 3.784L)
Tried this? :
http://www.performancelub.com/
Lol Daniel i can't work out why i keeps opening the ERD page, i thought you'd gone to new advertising extremes and played around with the shortcut buttons or something hahaha.
Cal-
Access denied to this website as it matched the policy: Category Web Filtering Policy
Your organisation's current URL filtering policy prevents your request from being allowed at this time.
The URL you are trying to access is: http://www.performancelub.com/.
The categories this URL matches are:
  • Business/Services
  • Entertainment and Videos
Gay work computer, will check it out at home.
Well, I haven't tried it yet but I can see if I can get that one to point to me too
Sean was looking for gearbox oils, just wanted to re-quote some forum annoyance :)
51cc in the combustion chamber of the head sound about right to you? Just went and did a quick cc of the head with valves and spark plug in and got that
Sweet thanks Cal, on the other site i found it $113 or something delivered so that's about right.
Hahaha Daniel i tried quoting you again i'm just not going to bother pressing any buttons on these pages anymore apart from "post" as it seems to be the only one the works for me..
Stocker was 54 I thought?
Its had a light skim, but I may have just been lazy and not tried for an extra few cc's
either way its about where it should be. Will re-do it later and working out the comp ratio when I'm keen to do some maths. Just gotta sit down and have a think about it
right now its to hot for that $hit :D
Also if anyone is after an Apexi Power FC for an R33 I have mine for sale now that the new one is up and running.
from anyone here I will take $1000 for it
Came out of the car yesturday, working fine, the only reason I went with a new one is that this one has quite an old version of the Power FC software on it and is a bit slow when tuning, plus I got a good deal on a new one :) its 100% working and has never frozen or stuffed up in anyway that I can recall. Comes with Hand Controller and has the tune from my car still on it at the moment but can be reset to base map with the controller.
Only bad thing about it is a few scratches on the ECU itself, but you dont see it behind the kick panel and it has no effect on anything inside :)
PM me if you are interested or know anyone that is
Don't worry about comp ratio.
If it's 9.5:1, don't run more than about 30psi
9:1 - 40psi
8.5:1 - 45psi
8:1 - 50psi
7.5:1 - 60-70psi
Easy :D
Lol im not worried about it, just curious as to where it has ended up
I know I have more then 8.5:1 and maybe slightly less then 9:1, so its in an area I'll be happy :)
just one of those things I want to know
    • Sorry the pictures suck. So hard to get camera and light in there
    • One of the first jobs with the E39 is making sure the tailgate stays up. In BMW fashion they made a little cavity under the roof to hide the dampers rather than putting them down the side like everybody else.  As you can see I have these little cavities that house the dampers. When I cleared one out and vacuumed as much crap as I could out of it I noticed a fair bit of rust. The cavity is bone dry, even after all that rain we had only a few days ago so I'm assuming that whatever allowed the moisture in is fixed but I'd like to treat the rust in there.  I was thinking of just blasting it full of rust converter but I didn't know if this would be beneficial considering I can't actually get in there to prep anything.  Maybe there's a better product?  Thanks guys
    • Had a few skylines over the years anyway bought this a few years ago for skidz i think it’s been around these traps for a while anyway I plan to thrash and trash and I assume it’s going to send me broke good times
    • The stock boost solenoid is just a valve. Power it and it is open. Unpowered, it is closed. When it is closed, there is no boost bleed out through the solenoid back to the inlet. The wastegate sees all the boost pressure, thus you get the wastegate's spring pressure as your boost pressure. 5 psi. When it is open, it lets some boost escape. This causes the static (boost) pressure in the line to the wastegate to be lower than the pressure in the intercooler pipe. There is probably a small restrictor in the solenoid or one of its lines to limit the flow rate of the escaping air, which limits how far the static pressure can fall, which limits the extra boost. The boost has to climb above the original/wastegate setpoint until the wastegate sees 5 psi. You get 7 psi in the intercooler pipework. A manual boost controller is exactly the same setup, just without the ability to change it on-off. It's always set to whatever you set it to. There is a small leak from the boost controller. The more you screw the adjuster in, the more it leaks, the lower the pressure seen at the wastegate and the higher the boost will be. So, yes, your diagrams are correct.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
