yeah well he has a 3mm one like the previous one i had on his 4ag and it was the heat/distortion/stress that prompted him to change mine...
rather some preventative maintenance before this shits in the car cos i would be slaaaaaack to change it in the car :yes:
Hmm i got a tuff decision, Do i make my own Dry Sump Pan or buy an ARE Cast one that bolts on easy as? I'm too slack to make my own but will save me more $$$ or just do an overtime at work to pay for it. FML :yucky:
Has anyone ever adjusted the std VCT inlet cam gear. I pulled mine off not realising it was slotted.
I dont really want to dial it in or anything like that cause it looks like a bit of a bitch to do (as the bolts are on the back). I've just got it about dead centre at the moment
Why did you undo the 3 locking bolts?
4 bolts. Because I didn't know they were slotted basically :)
Nah was gonna clean up the cam gear and vct cause they had a bit of surface rust. I've put it back so the washers cover up the slots so will probably be close enough
Ignore Chris, Callan. He likes boys...
If this were true, I wouldnt be waiting for my motor to be finished still :P
Cause it's about to go on a pallet motherf**ker.
So............... you like boys?
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
