ok so I've got my head back on and everything seems pretty good so far. Good old 3.0L purring away.
Been driving around a bit but the f**king battery dropped a cell. Left me on the side of the road. Won't buy century again, thats for sure. Its only 8 months old.
can anyone recommend a tuner down your way that will do a tune on a weekend? going to need a tune before the easter cruise
ecu's a Link g4.
thanks
rob
I do Powerfc, Link, and Vipec. ANd on a weekend, because I am not a workshop.
Can't do it on a dyno though, will need to be a street tune.
thats ok i prefer street tunes, will pm ya when i have a free weekend.
Disapointing results from my car today...... Only managed 240rwkw @18psi
Considering the turbo I have is supposed to be an improved version of the GT2835 Pro S, its quite annoying, Pro S turbos have easily seen 260rwkw and I have all the supporting mods to achieve that.
Going to do a compression test when i find some time and motivation, Bit of a blow spending all that money to achieve what I could have got with a high flow.
Data on the HKS GT2835 KAI for those interested:
HKS GT2835 KAI
thats not that bad of a result :cheers: , what suporting mods do you mean? and also remenber your in tropical mackay with huge heat and humidity!!!!!!!!!!!! do you have w/m injection? if not thats the best bang for buck and you'll get that figure your looking for. i garentee you who ever got 260rwkw would be at the same level if they came up here and hit the dyno. was that with robbie doing your tune? and pluse i would like to see the dyno chart i bet its got a great respone on that turbo so all the power would be in the mid range which would equal wheel spin city :rofl: but that depends on what your looking for. if it made great tourqe than who cares about hp even though i crap on about it still stuck on the old days of how much hp it makes not what tourqe did it produce. i bet its fun to drive though :cool:
Yeah I'm just disapointed that i spent so much on it when I could have gone for a hypergear for alot cheaper.
The Pro S's have got great figures, Joeyjoejoe on here has pushed over 300rwkw with E85, and was running 280ish rwkw with 98.
I wasnt targetting such high levels, but nice to know the turbo wasnt at its full potential in case I wanted to wind everything up
Dyno's correct horsepower loss from heat through intake air temp sensors (well as far as I'm aware anyway) so realistically same dyno in 2 different locations should read fairly similar
Its def fun to drive, Will be better when my 18's come. But still is a bit of a disapointment
Mods I have are:
Nismo 555cc
tomei in tank fuel pump
3" intercooler piping (stainless) with GKTech intercooler
Splitfire coilpacks
Power FC
Z32 AFM
NPC 10" Sprung Button clutch
3" turbo back exhaust (XForce)
Full HKS GT2835 KAI Kit (intake pipe, lines etc)
Thats all I can really think of atm, Think thats it
Hadnt thought about water meth but I dont think thats the issue. ATM I cant be bothered spending any more money on it, spent enough already and I've lost alot of motivation right now, so maybe in a few weeks I will see.
Pretty sure it's the turbo hey. Might try and get a pro s tune off someone and compare the maps. If there radically different I would say the turbo is limited
I'm in talks with nengun who supplied it and they are going to talk to HKS about it. ATM I'm putting no blame on nengun as they just passed on HKS information. So will see what they come back with
On holidays next week so car can wait for now.
You've probably got a massive boost leak somewhere... I'd say the stainless intercooler piping that you got someone to weld for you...
The tune is pretty damn good and there is nothing else I can think of that could restrict the power output. It's still not a bad figure, though. Every step forwards is a step towards a goal.
I'd say it was the turbo as well... What's your timing like?
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
