89CAL Posted March 9, 2011 Share Posted March 9, 2011 Lol you fool Timing was ok. A bit much in one spot but it's all good now. Yeah I know every step forward is a bonus but as I said, it's alot of money for 40kw...... Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5706586 Share on other sites More sharing options...
17psi r33 Posted March 9, 2011 Share Posted March 9, 2011 yea i was not really refering to the dynos more the weather conditions. water meth makes a great improvement for up here, you can squeze more timing safely with out the worry of pre det, plut extra fuel from methanol. what size rear did you get with that turbo? that's the usual choke point if the size was to small, you would notice a boost leak on your dyno graph depending on how bad it was. and its hard to be happy with out a goal, i guess the way to look at it as $$$$$$$$$$$= how fast do you want to go? then you reach that goal and start all over again cause your use to it and its slow again. i dont know how a top fuel driver could get through in life, imagine him driving his wifes toyota yarris!!!!!!!!!!!!! dear god come on it took like 5 mins to get to 100kmh! ha ha ha. still i must say you have a nice car, i see it all the time around town. Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5706854 Share on other sites More sharing options...
89CAL Posted March 9, 2011 Share Posted March 9, 2011 Thanks man. Yeah I'm getting over the whole thing lol Had set a target of about 270rwkw or so maybe 280 If it made it there. Was hoping to run e85 one day and just wind down the boost a touch so I was making roughly the same power with less boost. And have an agressive e85 tune to get me to 300rwkw and maybe a touch over even but yeah lol Pro s is capable of everything I've mentioned, hence the disappointment In ending up with this version lol. Sydney tomorrow so car is the last thing on my mind Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5707055 Share on other sites More sharing options...
17psi r33 Posted March 10, 2011 Share Posted March 10, 2011 hay cal i had a look at your dyno chart today not bad at all made good tourqe in the end, a little lower than 260rwkw but still not bad. it will be fun for you at the next test and tune. Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5708560 Share on other sites More sharing options...
89CAL Posted March 10, 2011 Share Posted March 10, 2011 Where'd you see that? Lol 18's get here next week so might feel a bit faster then 19's are just to big 760nm of torque I think? But that was in 3rd Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5708721 Share on other sites More sharing options...
17psi r33 Posted March 11, 2011 Share Posted March 11, 2011 im usualy at adrenalin performance, so i had a look while i was there. yea it was not 720nm it was 680 ftlb, its not accurate but that roughly work out to be 920nm! hence not accurate.(it was a bid let down for me to stupid dyno) if you make that much nm wheelstands would be occuring! its annoying to say at the least but generaly you nm output should be dam close to the flywheel hp of your motor, so 320 atw pluse roughly 20% for other losses = 384fly wheel hp so it should be doing around 390-400nm at flywheel. how come your putting new rims on your car arnt they 18's already? Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5709319 Share on other sites More sharing options...
89CAL Posted March 11, 2011 Share Posted March 11, 2011 Haha yeah couldn't remember the exact figure. But that's pretty decent. Nah I have 19's ATM (buy them off me? There nice ) Getting 18" Raiden (Lenso) D1R Snapped a driveshaft not long ago and I'm pretty sure it's from the big wheels with the large rolling circumference. Think they are a bit heavy to, but damn there strong and they suit my car pretty well Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5709399 Share on other sites More sharing options...
17psi r33 Posted March 11, 2011 Share Posted March 11, 2011 yea dont think snapping a half shaft or drive shaft it from 19's you get less grip with the smaller side wall and also under throttle you tyres toe in so less rubber on the ground, if they run gtrs into the nines with stock half shafts and drive shaft pretty sure we would be hard out to break them, i still have stock driveline and never broken it once, but i do take it off every month and check it all. if i was to buy rims they would be 15's or 16's, mickey thompsons are so much cheaper in that sizes pluse less wieght in rim. are you going to this import meet at bj's tommorrow? Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5710109 Share on other sites More sharing options...
The Mafia Posted March 11, 2011 Author Share Posted March 11, 2011 Cal, send me your dat file. I was thinking about the cruise. Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5710381 Share on other sites More sharing options...
89CAL Posted March 11, 2011 Share Posted March 11, 2011 Gtrs run thicker half shafts, I've done some research lol. Cause I thought the same thing, but turns out gtst ones are sligtly smaller but they still shouldn't break My wheels may just be to heavy. All I know is it does grip lots .dat file from latest tune? In Sydney right now, not home till Wednesday so I'll try and remember Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5710473 Share on other sites More sharing options...
89CAL Posted March 17, 2011 Share Posted March 17, 2011 Jeze been quiet in here...... Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5718549 Share on other sites More sharing options...
KING87 Posted March 17, 2011 Share Posted March 17, 2011 Just about to order my new wheels if anyone is keen on a set of BBS RG-R 18x9.5 +20 Or R34 GTR brembo brake package front and rear let me know.. Kingy Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5718628 Share on other sites More sharing options...
17psi r33 Posted March 24, 2011 Share Posted March 24, 2011 any one looking for some side feed injectors? i got a set of jec's 550cc just been bech tested and cleaned that im chaning out if anyones interesed. going to 850cc top feeds. hit the limit of those 550's already. Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5728703 Share on other sites More sharing options...
Mooney Posted March 24, 2011 Share Posted March 24, 2011 whens a cruise on? Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5728803 Share on other sites More sharing options...
89CAL Posted March 24, 2011 Share Posted March 24, 2011 New wheels turned up yesterday My Old ones are for sale now if anyone is interested. Chasing about $1500 (19 x 9.5 rear, 19 x 8.5 fronts) More details if anyones interested Heres a pic of them on the car:, photo was taken when I first got the old rims Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5728908 Share on other sites More sharing options...
Nur33 Posted March 25, 2011 Share Posted March 25, 2011 What made you change your rims Cal i didn't mind the old ones, i just ordered a new set for the R32 today should have them next week, got a set of the Latest AME Tracer TM-02 19x9.5 +22 they are gonna be the show rims waiting for a quote back on some Advan Neova AD08 Tires 275/30R19 can't wait they are gonna be awesome. Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5730388 Share on other sites More sharing options...
89CAL Posted March 25, 2011 Share Posted March 25, 2011 (edited) Main reason is tyres I always wanted 18's but im fussy with wheels and after choosing about 3 different wheels that I liked only to find out they didnt come in the right offset in 18" etc then I finally settled on the 19's I just took off. There a great rim, they look great and they are so tough, but every time something happens and I need to change wheels in a hurry, It costs me $600. I can get cheaper wheels sent up from down south but last 2 times ive had to change tyres its been urgent so had to source them locally. And I end up with Nankangs cause I cant afford anything better (Had a quote from one place for $700 EACH! for Yokohamas) And noone had the 19" tyre size in stock. The new wheels are really growing on me, but I still think the old ones are a great wheel I dont like those wheels on the black skyline there but should look good on a white 32 (Your not painting it a different colour right? haha) Edited March 25, 2011 by 89CAL Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5730573 Share on other sites More sharing options...
Nur33 Posted March 25, 2011 Share Posted March 25, 2011 Yeah i see where your coming from tires are freaking bullshit here in Australia, I've never seen them rims in the flesh before are they the D Project Ones, things always look different in a pic compared to real life. But Yeah not painting them AME wheels going for the panda look on the R32 Black and white is sexy gotta get the Enkei RPF1's powder coated black to match the new rims. Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5730593 Share on other sites More sharing options...
89CAL Posted March 25, 2011 Share Posted March 25, 2011 yeah they dont suit the black 34 but should look Good on a white car, How is the drag car going, will have to go check out the thread again, its been a while The D1R's are quite nice for the price they are, Alot cheaper then the Koya Inox R1's that just came off it..... lol Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5730599 Share on other sites More sharing options...
Nur33 Posted March 25, 2011 Share Posted March 25, 2011 Yeah the drag cars going ok, just gotta get it painted now then it's all done. Jason from HPI Magazine wants to be the cover car for one of his issues, so we are super happy bout that, can't wait for the finished product. Link to comment https://www.sau.com.au/forums/topic/139867-mackay-qld-australia/page/13/#findComment-5730613 Share on other sites More sharing options...
