So I'm selling Both of my new Apexi Power FC's, have got a response from the Apexi engineers and they say its my tune, but I've used the base map and played around with the timing in these areas with no results
So If anyone knows someone after an R33 GTST Apexi Power FC. I have 2 brand new ones. STATUS and others said they have had no troubles with these so it may just be an issue with my car, but I'm not really willing to chase it if they arent going to offer support.
Chasing $1100 for each Power FC. They are both the latest models, come with everything in box including new EL hand controllers.
Looks like I'm getting a link
Nah nothing to crazy, sensible car
just getting an A4, hopefully with an S-line kit and decent mags on it. Probably the only thing I'd touch would be the wheels. Park the Skyline most of the time, drive something that doesnt chew fuel and will be practical later in life. Thinking ahead and all that.
Should be sweet anyway. Bit nicer then a commodore
anyone know who stocks Motul 300v chrono 10w40 engine oil locally? tried calling autobarn but they were busy so i'll duck in there after work just wanting to know if anyone knew for sure a shop that has it in town.
cheers
I prefer Castrol edge engine oil over the Motul Oil. Castrol edge can cop a fair bit of punishment, tried and tested in our GTR and a lot of sport compact drag cars use it as well. Motul oil is very over priced.
I have Castrol edge in mine, honestly there isn't that much difference between them all. I perfer the Motul, it seems a bit nicer (quieter) with it, but at the end of the day most of the higher end mainstream oils will do the job.
I changed from Motul puerly to make life easier for me. I was having to order oil every time, where as going down to supercheap and grabbing a bottle of Castrol is much easier
I'm trying to get some info on Link + Link accessories but not having much luck with it. So far because I'm not that desperate for it I have just been emailing some Australian dealers and have emailed Link ECU direct. Link ECU gave me the closest dealer to me (Townsville) which I already knew but fair enough they are doing there job. At the moment I'm trying to find the info I need, I think I need the expansion cable to run the IAT sensor (as it uses an extra input) so basically I just want to know this and if they supply boost solenoids.
Also, My Power FC's are still for sale :)
Fault is with my car not the unit itself for those playing at home
Edited by 89CAL
That's the plan. Finally heard back from someone about getting one. Just gotta add a 4 bar map sensor and boost solenoid and should be a done deal.
Is there any setup for the knock control? I can see you can minister individual cylinders but I'm hoping it uses the stock sensors without to.much stuffing around. Haven't looked at the pin outs for the knock sensors might do that later
Vct setup looks easy, boost looks a bit harder to setup but probably just a matter of playing around with it. Hopefully won't be to hard to tune. Doesn't look to bad just alot more setup then the power fc
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
