power cruise in September sounds good.. Hopefully my car won't be too far off maybe take it down to Bris in May for a tune, see how we go.. Need to pay the mechanic a few more beers haha.. ;)
Millions of dollars is more preferable :woot:
  • Like 1
I'm sure most of you have driven paradise st of late.... Wht a joke the upgraded road there is already started to fall apart ...... All the wet couldn't be doing it good but surely it has to have something to do with the quality of work carried out as well ?? Then what would I know I'm a boilermaker by trade lol
Mackay Regional Council have a tendency to do roadwork's in the wet season... dumb f**ks instead on hooking in on the winter months and getting it done properly. They need to asphalt everything once instead on shitty bitumen repairs 10 times over.
yeah they love doing half-arsed roadworks then scratch their head when the wet season comes wondering why the road doesn't hold together for longer than a week without giant crater-like potholes appearing.. always happened in Mackay lol. Amazing how different the roads are in Townsville compared to here..
Yeah cheers mate ..... Went and got a wheel balance done haha what a drama that turned out to be as it had a lock nut on each rim which I couldn't find the key nut for so me assuming that any wheel and tyre joint would have a grip socket to remove them went down to only find out they didn't and were not willing to remove them with a ordinary socket which I have done tons of time .... So back home I go and 10 minutes later the lock nuts are off haha should have done it myself first time around ! Anyways turns out each wheel was out between 10 - 30 grams lol feels heaps better now !
kool kool. well ill send ya a msg when im heading home and ill chuck em in the back of the ute and head round. ill bring rotors and rear calipers if you want. front sitting on there so they dont leak out.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
