Yeahhhh but black cars look more amazing when they are clean :P
Think I might try the harbour shots again at night time, or in some lower light. Think they would look better like that. Might have to go do some light painting in a different area one day as well
might have to pay you to do some shots cal, or at least chat with you about what camera i should buy lol.
I have a shorter and a longer lense, obviously one zooms further. Then I have a prime lense which doesnt zoom at all, generally prime lenses will take a better photo but you lose the flexibility of having zoom.
My prime lense also has a better apature range. Without going to far into it, the prime lense I have is better for creating some depth in photos, and I find it gives a bit better colour. But it only focuses a minimum distance of 1 and a bit metres from memory in front of the camera.
Depth like this, not the best example but you get the idea:
IMG_3863 by 89CAL, on Flickr
I want to get a slightly longer lense then what I currently have, this photo from Formula 1 this year you can still slightly see the fence, If I'd had a touch more zoom I probably could have focused it out completely.
IMG_4571 by 89CAL, on Flickr
There's alot to learn, and I don't think you ever stop learning. But I'm self taught, just looking at other peoples photos and then working out how they did it. It's pretty good fun to learn, and nice going out and just playing with a camera
Anyway. I'll leave it at that :)
Thats an old photo. Those parts arent visible anymore ;)
Black is 100% worth the effort. You just have to put in the effort once or twice a year doing a full polish/buff and wax. Then its easy to clean and looks clean for a bit longer
Next car will probably be white but. But white suits it a bit better then white on a skyline
Sorting through some stuff today and found an old copy of performance imports with a Midnight Purple GTR in it. Real familiar one
ah righto. yeah most i ever did was at skool. but you can tell the differences between them all.. more stuff to spend money on i suppose lolbut after having a gun metal grey 180, those dark colours can piss right off lol. white has been the easiest to maintain so far.
Sold the V35 today. I'm going to miss it :/
Ah you will get over it Sean ;) cars come and go, I've had heaps of my cars in my time, you get sad for awhile then you get excited about the next car. You can always look forward to the next project/challenge. Set some goals and go for them, research is the key. I can't wait for my next project other than my FJ.
  • Like 1
That's what i am thinking about - it's the only way i can stay positive about selling it. I plan to save the money i was putting towards mods/on road costs insurance etc towards a house and get into property in about 12 months with my Mrs. Then start saving pennies for a GTR. i really would love a 33 V spec. In fact, Jordan if you want to sell me yours in a years time let me know man! haha.
hey all, i couldnt remember my old password for my old account but im here, been a wile from being in a skyline, but getting a r33 in the next few days...
o and i moved here from sunny coast. whats the cops like on modified cars here haha?
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
