Hey guysmoved to mackay 3 yrs ago bought a r32 gtst with a blown motor. Replaced motor but got mega issues. In the deep end for sure now but love the car cant wait to drive it when its going
Hey mate, welcome.
If you need any information, most people following this thread are very knowledgeable.
  • Like 1
Hey guys I have a problem. Replaced a blown rb20det with another. The new motor arrived with the timing out by 4 teeth. We re did the timing and got it running. But it is idleling rough as guts and the motor will die without throttle. If I give the throttle a tap it jumps up but then will go out of control. Up to 3 Grand then slowly comes back down. I have checked afm iac and cold start valve by unplugging them to see if I get a response. Which I do. I have power and signal going to all injectors and coil packs. All cylinders fire. The ecu has a ewad out of 55 which is no faults. Im out of ideas. Will do a boost leak test tomorrow with soapy water. SO CHEAP! Thanks in advance guys
Hey mate, seems like you have most of the bases covered. Usually the best way to test for leaks is to pressurise the intake.
If you are handy with a welder, weld a compressor fitting onto a piece of pipe with a tap, and weld the end shut. Them simply remove your AFM and clamp it there and slowly crank the pressure up to 30psi.
It is by far the only accurate way to find leaks.
Hey guys did a pressure test on the intake and I have a blown plenum gasket  the supplier I bought it off has a start up warranty on the motor the fact that this was already present has asked for a quote to fix and get the motor running. Lesson: warranty is awesome
looks like ur lucky there mate
After a new clutch cylinder for my car. (P/N: 30620-21U23)
Going to try Brakemart, Repco and Bursons, but just putting this up in case these fail and anyone has one lying around
Its a 3/4 Nabco slave, believe they might be the same as R32 ones, but not 100% sure
Hopefully should be able to source a new one anyway
Really? I dont go there that often. And I always forget to use my racq card anyway lol.
Ended up getting my slave honed and re-sealed by Better Brakes. They had it done in about an hour as well. Looks all shiny and new now :)
Works as well which is a plus
They were originally going to re-sleeve as well but said the bore didnt end up being that bad.
was just shy of $50, noone seemed to stock a new one. Was about to try nissan but dare say it would have been $100 plus
I don't think a re-sleeve would have cost much more, said it was going to be stainless re-sleeve so should last longer, but I'm happy as with the result. Like I said, looks like a brand new one after they sand blasted and re-kitted it
Have a funny feeling it might drive again tomorrow :)
I quite like 34's in yellow
get the wallet out Sean and just do it :P
Get the impression that this is really well looked after as well, has only been lightly modded. Would be a good one
Edited by 89CAL
If you're buying a BNR34 fro Qld, let me know. I know a few of the Brisbane bmr34 guys and they can give me the down low on the car. :)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
