Sweet as. Started editing some RAW photos yet?
Can make them look really good with just the initial processing in photoshop.
Post some up if you edit some :)
Like I said to you, I really wish we got more photos but that's just the way it went lol.
Yeah I have to get my FC Hako working again. The latest firmware seems to have screwed something out and it's dropping out. Was gonna have a look at everything at the drags but it kept dropping out early in the run
Got a thread uo in the for sale section but thought i'd throw it in here as a local sale wold be alot easier lol..
18x9.5 +20 BBS RG-R wheels
R34 GTR Brembo Brakes
PM for details
Cheers
Matt
Mmmmmm Brembo's haha
You gonna get your photo DVD from airlie? :P
That goes for all who were there to
Well have the Wideband in now:
Seems a little laggy (not to bad, half a second probably tops) but I dont know if it gets better as it gets hotter or if the gauge is just slow. The main point is the analog out from the gauge to run with FC-Edit so I can bring up the AFR's on the laptop and in map watch. Should make tuning alot nicer
Pacey: You might know this... Is there a way to bring up two map watches in FC Edit? I want to have AFR and Knock maps both up, but I dont think its possible......
Had a play yesturday but didnt really get anywhere.
This looks like much more then 2 degrees of camber........
Used some Turtlewax bug and tar remover on my rear pods to get all the tar off that the tires flick up. Works a treat that stuff
Edited by 89CAL
Lol looks closer to 5!
Yeah I think pedders may have dropped the ball on that one. My report said 2.1 degrees or something.... Doesnt look right lol.
Did a little playing around with my tune today. Trying to fix a funny spot. 5th gear foot down and it goes 13.2 then climbs to 14ish then back down, weird. Added some fuel to a cell that looked like it might be the problem but its still doing it so not sure what the go Is....
So got my new front cover for my turbo made up......
The thing sounds even louder then before! I thought without the anti surge slots would make it alot quieter.
Anyway the thing is so rich now I'm lighting up the night with backfires so will need to play with the tune on the weekend (10:1 AFR's atm)
Wheelspin in second easily now but, if it wheelspins in 3rd after tuning then I may have solved the problem with the HKS GT2835 KAI and its disapointing results in comparison with the Pro S
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
