yea i think your right there, just putting cash aside now for t400 auto box and trans brake so im expecting to break diffs and axles more often when i get it all in the car. i found billet axles for my car rated to 1000hp for 550 delivered so if i break them again ill just upgrade. diffs i have just not axles.
Are they for Gts-t cause I only ever find GTR ones which I assume are longer?
Debating wether it's better to have the driveshafts as the weakpoint or not cause if I get stronger ones it's only gonna be something more expensive that will break instead......
Driveshafts should not break if the suspension is setup properly, the only other way they will break is fatigue from doing a million launches in them. If you have have really hard spring rates like 7-9kg/mm on the rear well that is way to hard, and if your car gets axle tramp when the wheels spin well that will also cause it to be weaker. Personally i don't know if GTR shafts are longer than GTS ones but i'm gonna guess and say they should be the same. If you are gonna be drag racing the car all the time then its probably worth spending some coin on the rear end suspension getting it right so when the car squats for a launch the driveshafts are as straight as possible. + dumping the clutch at 6000-7000rpm is not good either as this shock loads the whole drive train, in GTR's when you dump the clutch at 8000-9000rpm all the time i guarantee you will end up breaking something really quickly, need to side step the clutch by releasing the pedal slowly and letting the clutch grab slowly it might just save the drive train a bit of shock load. I see people all break shafts all the time, i've owned skylines and GTR's now for 6yrs + and have never broken a drive shaft yet and i thrash the shit out of my cars ask Kingy he can concur with this lol thumbsup.gif.
Haha yeah. I think my driveshaft that snapped was a bit of a random thing. Ask anyone I don't really do hard launches around town, I'm a girl and all that shit yeah yeah :P
But it's always in the back of my mind now, I'm mainly worried about if I ever get semis. But I need to slip the clutch a bit next time I go out for a run. The button clutch won't make it easy but I'll manage :)
cal, I did stacks of drags and launches and stuff, and with semi slicks and never had an axle problem. I think your problem was a bit of a fluke.
Also, always let the clutch out, never side step. Too much shock, and you'll only create unwanted wheelspin.
Does beat the shit out of it..... When its not parked up being worked on lol...:P
Ben, would t waste your time with the dirty thirty.
You're better off with the dirty whore, thirty four. Haha.
The rb30 cranks are a bit old to be spinning hard. The rb34 kit from spool has a billet crank in with the package. Costs $5k. Spin the f**ker to 10k and bolt twin gtx3071s on it, haha.
You need to set the record straight with the xr6ts ;)
Ah i got 2 RB30 blocks at home a shitty N/A block and a Turbo Block, should just sell them and spend it on my N1 engine or sell the lot and twin turbo the Z, hhmm never own 2 good cars it just makes it harder to figure out what to spend the money on.... someone buy my GTR i'm sick of looking at it.
the NA blocks are just as good as the turbo blocks (exactly the same) if they are a series 2 block. They have the oil and water lines for the turbo. Just bunged up.
I'd use one for the RB34 ;)
How long do you think Cals engine would last with the TO4Z on it? haha.
Lol Stock RB25 with T04Z = LAG MONSTER i'd give a week before it would blow a piston and rings to bits rolleyes.gif
I remember my mates R34 GTT i built for him with a GT3540 on a stock engine, damn that thing had bulk lag but was awesome fun on boost.
Seen an RB25 with a T04Z (all be it not as new design as the one you have) and yeah..... No thanks lol
The only reason I went HKS was for good mix of power and response, would have been more then happy with the Pro S. I'm sure of that
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
