Don't know if any of you lads are interested but we are getting team shirts made up for our R32 GTR Drag Car, Prices will very depending on how many we order but they will be approx $40. Just PM if you do want one and the size you would like.
Cheers Benny
Will look something like that:
Is anyone interested in my HKS GT2835KAI turbo?
Will probably look at selling it soon and just wanted to see if anyone local wants it
I made 255rwkw with it @ 18psi
just EOI at the moment. Probably just the turbo itself as well as the oil lines
Could be interested bro
yeah i might be interested too callan ;)
0448 233 105
He's from Mackay.. Knows this shit backwards. He's a guy like you and me, and the rest of the crowd.
Very good with suspension too due to the whole drifting scene.
Thanks again Jono i gave him a call, he's going to check it out on Friday for me
damn ben you guys don't stuff around. it'll look good once ya get it pieced together.
cal- go the 3076r, it will change your life :P
nic- just finish the sil80, if ya go a 3076 on the 34 don't go the 6 bolt housing, it'll make decent midrange power but for what a dump pipe costs go the .82iw
I'm pretty set on going Hypergear right now. After the cost and annoyance this HKS turbo has caused my I'm reluctant to go for another one (pretty sure Ben was talking about his HKS turbo he is selling)
anyway, the main benefit of the Hypergear turbo is that I can just change my mind whenever if I want to go ext gate or even if I want to get updated parts/housings/wheels.
It's just a bit of 'playing it safe' I guess you could say on my behalf, Stao is local and easy to contact/deal with.
Having said that, its not like they are comprimising to provide any of this, I've seen plenty of good results
Cal, the hypergear won't do much better than the 2835. There is also nothing wrong with the GT3037 HKS. They have a better rear housing and IW than the garret version. They also make more power because they have a larger 76mm compressor.
The turbo I'm going for will be 300rwkw @ 20psi on pump fuel, full boost 3700ish rpm (getting 6boost manifold)
The HKS 2835KAI is only making 255rwkw @ 18psi with full boost around 3400rpm
I've spoken to others and this is all they are making
The Pro S that I originally wanted, sure. Would be more then happy with it
But the KAI has proven to be nothing compared to the Pro S.
There must be something up.
I made 300rwkw with a garrett GT3076 and 0.63 rear housing at 18psi - 20psi. Full boost in third at 3200rpm. That was with the little IW too. You can get a custom garrett IW that is bigger and handles high boost better.
The 0.82 rear housing shits 300rwkw in at 18psi. About 500rpm lagier though.
Its a direct replacement to your current turbo too. Well almost, I think the HKS rear dump pattern is a little different but that is easily fixed.
And why are you wasting money on a 6 boost manifold? All of my results were with a standard manifold. If you want to make the standard flow better (more like a HKS cast one) then hit it with a die grinder and clear out all of the lumps. I did that with the standard manifold I used for my RB25\30 build, and bam, 320rwkw with 20psi from the same Garrett GT3076, 0.82 rear housing, IW. Had Tomei 256\256 poncams though. Full boost in 3rd at 3000rpm, and 820nm of torque at 3000rpm.
Its a weapon. Still going good too.
My advice?
Get a GT3076 or GT3037, 0.82 rear housing.
Port your standard manifold, and get it faced
Port match your Rear housing entrance to your exhaust manifold output
Get some Poncams, 256/256 or 262. Anything bigger is a waste for the RPM range you are using.
Get someone to look at your tune
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
