The turbo I'm going for will be 300rwkw @ 20psi on pump fuel, full boost 3700ish rpm (getting 6boost manifold)
The HKS 2835KAI is only making 255rwkw @ 18psi with full boost around 3400rpm
I've spoken to others and this is all they are making
The Pro S that I originally wanted, sure. Would be more then happy with it
But the KAI has proven to be nothing compared to the Pro S.
Thats about the same as my ss1pu on 16psi psi of boost, full boost on 3250rpms 4th gear. Run 3076R in .63 rear internally gated on your current setup won't make much more then what you've got, probably just add in more lag, unless you turn that on a 6boost with a large externally gated, unless turning into e85 or WMI.
Pretty sure Hypergears makes biggest bolton internally gated turbos you can find, How ever won't make their peek efficiency been used as a bolton, I believe the limit is 280rwkws unless you go for a better manifold or butcher the stock manifold.
Your 2835kai already has a 3071 core, you can just get the surge holes plugged and run that on a high mount with externally gated setup, that should be getting around the 280rwkws mark. Best have a look through the dyno sheet section for what manifold, gate and cam setup that most people have got and made 300rwkws+ with.
Edited by petero'nell
Yeah 280rwkw was the goal with the 2835 although the pro s' do push a little past that at times
The goal is a g2.5 int gated on the 6boost manifold. E85 later on to push up near 350rwkw (going off stao's results)
There's much more going on pre Turbo but the Turbo was gonna go on in the mean time so I can sell the HKS Turbo
Rob: Greddy rip off has been solid. No issues at all. Will have a proper look when I pull it off but looks good so far
Get the latest SS2 and put it on a 6boost, much better response. their prices has been marked down recently. Run that on a high mount and external gate and E85 it probably be making more then Stao's car as he always been running internal gate.
New Origin +50mm Overfenders have turned up look pretty awesome, i have also ordered my rims today :woot: f**k yeah can't wait ended up getting Work Meister S1R Front: 18x9.5 +12 R Disk and Rear: 18x11.5 -8 O Disk. Gonna look pure sexual.
IMG_0137.jpg?t=1343196131
IMG_0136.jpg?t=1343196095
IMG_0135.jpg?t=1343195966
IMG_0134.jpg?t=1343196003
A little bit more shit to pull out and she will be ready for fully chassis stitch weld and rollcage. Show much shit to get thrown out i managed to fill a box trailer and my wheelie bin so far and my shed still looks like a junk yard.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
