When are you gonna get Dyno'd? I'll talk to Robbie for you and see if you can get it done for cheap. All you need is power runs, don't you? I've been meaning to get a base power run for mine before the new engine goes in.
Yeah we went to adrenaline, just rocked up to try our luck but he said there pretty busy for the next week (till thursday)
So might try and book it in for saturday. Yeah just need a power run to see where its at
just had adrenaline retune my car with new turbo installed, must say rob does a good tune each time! great results as well verry happy will be much more fun at the strip this time around when the dam rain pisses off!!!!!!!!!!! hopfully the 25th of this month will see us all out there haven a few runs. them all these bloody holden and ford lovers can bowe down to the rice burners!!!!!:worship: ha ha ha ha jokes jokes there are a few fast ones around thats for sure, stupid xr6t! little modes and big power out :banana:
ill be in for any cruize any time!!!!!!!! any excuse to go for a drive, and the tune ended up at 492rwhp so far a little more in refining the tune and should be maybe a little more in it. ran out of fuel in the injectors so that will be the next thing. car drives great so far so will be keen to do some 1/4 mile times. i got slicks this time and changed the rear diff ratios so should be a bit more fun
well that depends on what turbo your running at 18psi? still will be good figures, it will be more responsive than me on the road thats where is counts. not that mines a huge lag monster but the 3076r garrett i had earlyer this year was a ball tearer!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
