That is awesome Kingy. I'll never forget that day we checked the tune and it was pulling like hell from 2,000rpm onwards.
Shame the clutch started slipping. I would have loved to see the full potential.
I guess I'll just have to wait a bit longer and get one for myself :)
I was getting 20psi by 4500Rpm
Yeah mine were about the same just over 4000rpm both our engines were identical specs except mine didn't have dust and cobwebs all over it from been parked in the shed hahaha
Speaking of manifolds.........
Slapped the Poncams in for a little look, might have to do something about 1 or 2 of the cam caps, but other then that it looks pretty good.
I hope you haven't got valves/lifters in place? :(
Just wish I could throw it all together, Theres gonna be some stuffing around working out CR and working out what head-gasket I need to get as mines going to be a touch to Thin. Think a 1.5mm gasket will be OK
Have to grub screw the crank collar on as well. Just got an email saying I have more bits on the way from Kudos so should have them by the end of the week.
Still waiting to hear back From HEL UK about my oil cooler kit. I payed them a few weeks ago and it hasnt left and they havent replied to my email, might have to send another.
I think I'm gonna have a play with paints tomorrow. Might Try painting my spare cam covers tomorrow, Spray some Wrinkle paint on then paint the EVOKE over the top which is the colour my cam covers are at the moment, Just for something to do... lol
Them UK dream boats are always slow with sending shit, I avoid them like the plague + there postage is through the roof.
Just ordered a shit load of Mc Shit from VPW to get my Turbo sitting pretty on that Manifold. Next on the list is to order all the titanium pipe I need for Screamer and Dump Pipe all of the R32 Titanium Piping turned up this week it's going full Titanium Turbo back and external Titanium screamer out behind front wheel through the side skirt that will save almost 20kg in weight over old 4" Stainless system.
i need a titanium exhaust.. one day. bout to put the oil filter relocation kit in. just made up bracket and gotta pretty it up a bit. few carbon items will be getting added also. anyone need a carbon exhaust shield, and carbon timing cover. come with a kit
Reply from HEL tonight. Kit getting sent out today :)
10 pounds postage, don't know what you were talking about Ben :P I thought this was the problem (they hadn't accounted for international postage)
Not bad all up $460AUD all up I think it was for the thermostatic oil cooler kit with 19 row cooler and braided lines
Callan, what CR are you aiming for? Would be nice if E85 was here.. Could build to 9:1 without an issue. Maybe even a tiny bit more.
Also, what is your view on restrictors? I went 2 x 1.3mm with the blocked VCT (For the 3.0L) and at 85psi there was a tiny bit of oil in the can. Dropped to 75psi - 80psi and no more oil.
Have to work out CR probably this weekend when I do the dummy build. Will be between 8.5 and 9 to 1 though
I have a 1.5mm restrictor and a blank for mine. Wasn't going to block one but after talking to a few people who said they didn't and then had to pull the head off and put one in I thought I should.
Awesome. I built the RB30 with 8.4:1, and I wasn't happy with the low end power. You can really tell when you're missing that bit of CR. Mostly off boost. Even with the 256's in, it could have been better. Especially with a 3.0L!
I had luck with the 2 x 1.3mm but if you're happy with 1 x 1.5mm then try it out and see how you go. Are you increasing the oil pressure? I opened my clearances from 2.2thou to 2.35 thou and bumped the pressure up 10psi - 15psi. Guys on SAU said its kind of like this:
2.2 thou - Factory
2.3 thou - 300rwkw
2.4 thou - 400rwkw
Just sharing some notes anyway.
If you are going to play with oil pressures, save yourself weeks by cutting a hole in the sump and putting in a bung so you can change the springs in the oil pump without having to take the sump off. Quite a few people are doing this now. My mate did it and had to change his pressures about 3 times. Saved lots of time lol. Leon would probably tig one on for next to nothing.
Edited by The Mafia
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
