You heard it. Morpowa, Saturday 17th May, 8.30am kick off. $35 bucks a head. Got some good interest so far, and even better the dyno is being calibrated by Dyno Dynamics this week to be 100% accurate for the event.
Matt, if youre up to it you want to help me organise some numbers? Cheers.
MORPOWA
14 FAMECHON CRESCENT
MODBURY NORTH
SAU ENTRY LIST:
Nightcrawler - S15
MattR - GTS-t
Freebaggin - GTS25t
PHAT 33 - GTS25t
grepin - GTS25t
Nozila - GTS25t
Busky2k - S14 200SX
  • Replies 130
  Quote
Yeah sure mate :P I'll sticky the thread for starters.
I also have a few mates that would be interested in taking their cars on the dyno so if that ok with u i could get about 4-5cars there.... if u can tell me how many cars u are looking for on the day i could try and get some numbers for u...
thanks
If I get it, put it down as a hybrid and its white. Hey andrew those mags you were looking at where were they. If I get this new car I will be selling the 18s that are on it and gettin something else. Cheers Matt
i will try to bring:
2 - Soarers twin turbo (1 is limted ed. but i dont think any internals are different)
1 - 180sx
Another thing is that im on the southern side of adelaide so i'll have 2 try and figure out a way transporting them.
I also have 2 confirm my mate's cars but should b able 2 get at least
1- R32
1 - 180SX
1 - S15 Sil80
all the cars are faily stock, just usual mods like a/m air filter, exhaust... nothing too crazy.
I'll tell u the definate numbers as soon as i can.
thanks
Hip,
Every dyno day I've been to each entrant has had at least a couple of power runs (2-3). So you'll get a chance to do a low boost run, & then a high boost run :D
    • By went out the old cluster completely died first it was the odo lcd then the gauges stopped working, Nissan said the board/chip went bad. I then ordered a used one off of amazon. I can transplant the speedo gauge itself I still have the old bad cluster. in fact I am trying to visually inspect to see any differences between the two. The back of the speedos themselves have a different number on the top one has a 5 the other has a 6 i believe printed at the top and the original motor looked a bit larger. On the board itself behind the speedo I saw a few differences looks like towards the bottom the my original board didn't have a resistor at R3. The SMD chip in the top right has some different numbers on it (maybe I can swap these) and the resistor at r16 might be different colors. So the new cluster came from a non turbo but it did have TCS the ebay seller said. hopefully these images will show:  New cluster broken cluster   I will try to transplant just the speedo first.
    • I'll match that and include 3 out of 4 of the speakers in a set of Alpine front splits.
    • *all RB25 s1 if I hadn't said yet, sorry guys haha
    • Yes, the speed sensors are quite different between NA and turbo. Completely different waveform. I'm surprised it's picking up any pulses at all if it is the wrong one. As to the original problem... "the instrument cluster went out". What does that mean? What died and how? Is there any hope that you could transplant teh speedo head from that into the new one?
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
