You heard it. Morpowa, Saturday 17th May, 8.30am kick off. $35 bucks a head. Got some good interest so far, and even better the dyno is being calibrated by Dyno Dynamics this week to be 100% accurate for the event.
Matt, if youre up to it you want to help me organise some numbers? Cheers.
MORPOWA
14 FAMECHON CRESCENT
MODBURY NORTH
SAU ENTRY LIST:
Nightcrawler - S15
MattR - GTS-t
Freebaggin - GTS25t
PHAT 33 - GTS25t
grepin - GTS25t
Nozila - GTS25t
Busky2k - S14 200SX
  • Replies 130
Yeah sure mate :P I'll sticky the thread for starters.
I also have a few mates that would be interested in taking their cars on the dyno so if that ok with u i could get about 4-5cars there.... if u can tell me how many cars u are looking for on the day i could try and get some numbers for u...
thanks
If I get it, put it down as a hybrid and its white. Hey andrew those mags you were looking at where were they. If I get this new car I will be selling the 18s that are on it and gettin something else. Cheers Matt
i will try to bring:
2 - Soarers twin turbo (1 is limted ed. but i dont think any internals are different)
1 - 180sx
Another thing is that im on the southern side of adelaide so i'll have 2 try and figure out a way transporting them.
I also have 2 confirm my mate's cars but should b able 2 get at least
1- R32
1 - 180SX
1 - S15 Sil80
all the cars are faily stock, just usual mods like a/m air filter, exhaust... nothing too crazy.
I'll tell u the definate numbers as soon as i can.
thanks
Hip,
Every dyno day I've been to each entrant has had at least a couple of power runs (2-3). So you'll get a chance to do a low boost run, & then a high boost run :D
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
