Hey Guys & Girls
I have noticed my line is making a funny noise that sounds like I have a piece of wire dragging on the road (but I haven't). It is very noticeable a low speed.
I think it may be brake related:(
Anybody got any idea what it could be??????
https://www.sau.com.au/forums/topic/13989-funny-noises/
If its been a while since a pad change, some pads have a metal tag attached tot he side of them which will start rubbing on the rotor when its time to get new pads, only prob is theres usually another 10k worth of pad life oleft so i used to just bend the tag out the way when it happened..
best to pop the hweel off and have a look at all your pads, and check for anything out of place, or pop down to your local mechanic and get them to give it a check over..
cheers
https://www.sau.com.au/forums/topic/13989-funny-noises/#findComment-280662
Thanks for the suggestions everyone:D
I have checked the fluid levels. ok
Checked for anything hangin down from the bottom of the car. ok
So I'll rip the wheel off tonite and check the rear brakes, would make sense now that I think about it the noise started after a rather big :burnout:
:P
https://www.sau.com.au/forums/topic/13989-funny-noises/#findComment-280803
  • 3 weeks later...
Found out what was causin the noise.
When the brake pads were replaced someone put clear silastic stuff on the back of them?
As this has fatigued it was interferring with the return of the brake piston and therefore the pads (both front) were rubbin on the disks.
Anybody know why someone would put silastic on the back of the pads???
https://www.sau.com.au/forums/topic/13989-funny-noises/#findComment-315886
Yeah, bendix ultimate's squeal when cold, and release quite a lot of brake dust while driving... grrr!!! And i've got white wheels!
Bendix premium on my previous car released no dust at all. but still had brake-fade :)
Impul: I noticed that when you drove past me on the freeway not long ago... i thought "his pads are rubbing his rotors" must tell him... hehe
https://www.sau.com.au/forums/topic/13989-funny-noises/#findComment-316970
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
