steering bushes / rack are apperently fine, 2 mechanics have looked at it , i wouldnt know a thing about it myself
i can't see any evidence of acidents and i'm sure suspension places or mechancis would have pointed it out as the easy way out of a question by a customer (should be easy with the car on a hoist which they have had it many times)
i went to swap my friends r32gtst 4's wheels to brothers r32 gtst just yesterday. turns out that suspension components must vary greatly between these two cars, as there was insane scrubbing with 18's on the gtst, so we werent able to test the car with new tyres and wheels!!!
i might look into the discs being out of balance. will a simple machine of the discs pick up on this?
The commodores are well known for their tailshaft center bearing crapping its self, especially the VN's. :)
They will send a vibe up through the steering wheel on accel and when it gets worse on cruise. I had mine done on the VS 5ltr twice, they don't last too long.
My tail shaft uni joint is shot to hell in my commodore. It shakes the steering wheel to the shit house.
Change the uni joint. Problem gone.
Regarding the shake at 110km/h. I had that with my old gearbox in fifth gear. Drop it back to fourth and there was no vibration. The vibration you could feel up through the seat and slightly on the floor pan. It would slightly vibe the revision mirror where it was difficult to focus in on cars behind.
New gearbox after it stripped third gear and no more vibe.
So try that.. Get it vibrating.. Drop it back a gear and keep cruising. :)
before you spend another cent swap all 4 wheels with another set even if you have to beg borrow steal them just to test the car.
wheels are the largest ammount of rotating mass and will be the easiest/cheapest thing to fix/diagnose.
cheers :(
you would thing flat spotted tyres would be picked up in a simple balance?
A flat spot will just show that one side is slightly heavier, add weight to the other side. Problem still happens that the tyre goes round round round FLAT round round round FLAT.
Each time it hits a flat, it "hops"/"shakes"
Major badness!
the tyres on the front are brand new, my brother doesnt lock up the brakes
before i could suggest an on car wheel balance he has got the discs machined and said that its fixed 90% of the problem. yay. so its better then its ever been but im guessing there is still something there
thanks for your help so far, i wonder if the rest can be fixed too
hi there.. where did he get the disc machined, how much did it cost and how long did it take?
did he have to take the disc rotors out himself or just drive to the disc machiniing place and they'll do it all.
thanks
dont know any of it
but its hell cheap and they'll do it all for you and it doesnt take long
even kmart tyre and auto does that stuff! its like $20-$30 a disc, all labour included
but it'd be best to do an on car wheel balance, it would compensate for anything being out of sync. -unless you are getting vibrations when braking (warped discs, fixed by machining / new discs)
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
