How different would the results really be from an Rb25?? I'm going to be playing with an RB25DET Neo Powered R32 GTS4 soon, will be getting either a GT3076R, GTX3076R or T67-25G ... depending on where the owner goes with that. I'm quite interested to see how that goes.
blast from the past. I never did it but the idea still hangs with me. I might do it one day. thinking about a small-ish borg warner EFR TS/twin gate set-up. could be nice.
since this thread I built my GTR with GTSS, another one with 2530s, and yet another one with 2530s so still rocking twins. current GTR is jun 2.7 engine with 2530s but thinking about putting it onto E85 now and wind up the wick a bit.
Hey there,
New to the forum and wanted some advice on SST upgrade for R32 GTR.
Built motor (rods/pistons/cams/cam gears all the usual stuff)
Basically just looking for response (only 260 poncams)
What's your opinions on HKS 3037?
Cheers
Looking at the rb25 sticky, the hks 3037 is making 280-300kw, is that acceptable? A built rb26 is probably better than the rb25s in the sticky thread. There are established good response, better power twin low mounts, set ups well described. I like the simplicity of a single setup.
Edited by WHITE gtt
Hey Rich,
My GTR initially had an Apexi IHI RX-6 TCW77P25. Stock RB26 with a couple of cams. Little baby, could only make 400hp atw no matter how much boost I threw at it. left it on 19psi, super responsive, full boost well under 4k ran heaps of mid 11s at the drags. (ps if anyone wants it - it's sat in the garage at home with manifold, wastegate setup etc). Upgraded to a GT35R and overcame the tempation to go to the T04z and the like. Useable power > *
A new GTX3076 or whatever they are would be wicked.
Mick
still getting used to posting and such. Sorry about that.
Yeh 300kw would be acceptable. Just looking for a nice responsive thing that you don't have to wring its neck evrerywhere
Edited by Whiskey Ghost
  • 3 years later...
Hey guys, been doing some reading and found this old old post.
Can't find to much more on the subject.
I am currently setting up a small turbo on my r32 gtr, after putting n1 turbos on and hating them I decided I was never going through the twin turbo shit fight again, and I couldn't see why one turbo, wouldn't spool up better than two that are similar size combined, you have less mass to turn, in one turbo, and less bearings, less friction, maybe I'm wrong, but I couldn't find a straight answer anywhere so I decided I needed to do it myself.
I have a STD engine so won't be chasing big power, so I decided I would go for response instead, I have a very low budget and have done all the work myself.
The turbo I chose was a kinugawa tdo6sl2-20g ($1000)
This is t3, internally gated and has a 8cm rear housing. It came with all the gaskets and hoses I needed to fit it to the engine, didn't have to buy another thing in that area. Have heard alot about these turbos and really wanted to give one a go.
This is bolted to a ebay manifold ($350), and did some custom intake piping from some silicone joiners off eBay and some alloy pipe laying around at home ($50)
For the dump pipe, I used 3 inch flexible stainless truck exhaust ($60), down to the cat, this is welded onto a vband flange which came with the turbo
I know some of you would be cringing by now at this set up, but I'm into trying somthing Different.
I brought a second hand adaptronic e1280s off my mate for $500 and wired in a map sensor ($60)
The set up hasn't run yet, just in the final stages of setting up the adaptronic, I have heard of people making 300kw with these turbos on sr20s and rb25s, so I don't see why the 26 won't do it, and it should have very little lag which will make it awesome to drive and look after my STD engine, not having to rev it hard to get ssomewhere.
Or it might just not work... Haha we'll soon find out.
Let me know your thoughts guys
They were r34 gtr n1s
Were never dynoed, they would have been alot better if tuned properly and stuff but I just wanted single for the ease of working on the car.
The n1s got on boost at about 4-4500 which I was not stoked with.
I've done a number of tests based on small singles fitted to a unopened GTR engine. You can find more details on my thread.
Be brief. I've fitted one of my TD06SL205 Turbocharger on my GTR externally gated in 10cm rear. It runs off a TD06L2 turbine, with a compressor that is15% more efficient then a standard 20G without adding lag. This is a proven turbocharger working with SR20 and Rb25 engines.
On Rb26, because the head flows so well, the extra rev and engine capacity, this turbo can not keep up with set boost once the engines revs over 5000RPM. Stronger external gate spring only caused higher boost spike in mid range while made no changes up top. Been the Kando's standard TD06L2-20G, your boost tapper should be even worse.
Best power was 308awkws pump 98 fuel, Vs factory Twin T25s
On E85 the best run was 367awkws, and averaging of 350rwkws.
Goal was responsive 400awkws, data from the following evaluations shown that I could never get that. Lead me thinking twice of why Nissan have chosen to twin turbocharge this engine.
Anyway, I don't usually stop till I get there, so scraped every thing I knew about Rb25det and start fresh, many weeks of modeling, testing and $$$$$ later (Check details on my thread), it worked.
ATR45SAT / AKA ATR43G4/SAT. 411awkws @ 24psi, E85 Fuel
Power and Response Vs Stock T25s
This turbocharger has been left on my car since.
Ps. It doesn't cost much more then what you've paid. List your TD0620G back on Ebay and fit this instead.
  • Like 1
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
