hi installing my ebc
only wires that need to be connected are power and ground
silly question time
were is it best place to find a +power source and a ground? i'm putting the ebc in the ash tray (stealth style). So i was thinking of using the cigarette lighter power and ground. Or do i connect the ground to the metal of the car somewhere?
anyways which is the power on the cigarette lighter? i have a black wire and an orange and black wire. Theres a grey and blue wire in the same harness but it doesn't connect to the lighter.
also is it best to have the connected or disconnected when doing this?
thanks
Troy
https://www.sau.com.au/forums/topic/13993-where-to-find-power-and-ground/
How many amps is the EBC rated at? If you connect into a circuit, you need to make sure that you dont overload it by having either too large a fuse (a power surge may result in damage to EBC) or combine current drawing from both devices results in fuses being blown (exceeding the max amperage the fuse is rated at).
If you have an inline fuse on the EBC, then you can connect the power to the live side of the fuse box. Test this by pulling a fuse and then connecting the wire to either side in turn, when you get power, you got the live side.
Ground, have a look at where your stereo is earthed, should be a good spot.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
