1993 Nissan Skyline R33 Series 1
Metalic Blue colour
Larger turbo
Stage 1 Nissan Cams
After-market computer (Apexi Power FC)
Apexi AVCR (Actuator Valve Controller - Boost Controller)
K&N Pod filter
New air flow meter
FMIC with custom plumbing
front strut bar
d2 coil over suspension
off set caster bushes
fully adjustable camber control
Nismo LMGT3 limited edition (genuine white) (18'' x 9'')
3'' Momo CBE
HKS SSBOV
Lightened chrome molly fly wheel (4.5kg and brand new)
Exedy sprung button clutch (brand new)
Interiorhttp://www.skylinesaustralia.com/forums/index.php?
Apexi Power FC
Apexi AVCR (limited edition black)
Razo Turbo Timer
Momo steering wheel
Dual gauge pillar (A/F and Boost gauges)http://www.skylinesaustralia.com/forums/index.php?
Genuine V spec GTR dash cluster
Body
Nismo clear side repeaters
Full GTR body kithttp://www.skylinesaustralia.com/forums/index.php?
LED rear lights
Razo shifter
Razo pedals
Sound System
Clarion type r 6'' splits front and rear
Clarion 330watt AMP for splits
15'' POLK Momo Sub with custom box in boot
Sony 1400watt AMP powering Sub
MOngoose 10,000 Alarm/Immobiliser
Addiotnal Info
Tuned by Dale at Castle Hill Exhaust. Ran at 260HP at 7psi, has loads more potential only limits are the injectors which could be sourced. Has small dent passanger door, and minor scratches and stone chips. The additional body parts are not fitted or painted. Taken care of immaculatley and only put on 12kms in 2 Years. Total of 113k kms.
Rego till July next year and just serviced 3 days ago and every 4 thousand kms. Oil used is only REDLINE and fuel is only ever Either BP Ultimate or Vortex 98 Octane.
Very reliable and has never broken down on me, reliable and fast car in one.
Extra
Brand new power window motor and regulator (installed)
Brand New Clutch (installed)
Blitz Brake Pads (installed)
New battery
Flush mounted boot (no wing)
2'' wider front guards
Drift bonnet with vents
serviced every 5000km (oil and filter)
reciepts for over $15000 worth of work, but much more spent.
Price
$21,000 Negotiable, Willing to hear reasonable offers too.
PRICE DROP $20,000
PRICE DROP AGAIN - $19,500
Possible swap for good quality S14a
Located in Wollongong, NSW...
Contact me via PM if interested or any Q's.
Edited by jakegts
https://www.sau.com.au/forums/topic/139936-sold/
PRICE DROPPED TO $20k
Also willing to:
Remove NISMO LM GT3 Rims to stock or
Remove Stereo to stock or
Remove spare fibreglass bonnet, spare fibreglass sidefenders, and spare fibreglass flush mount boot
in an effort to reduce price.
If potential buyer would like all items removed for a cheaper purchase price please PM me or just PM with an offer, will take into consideration.
Edited by jakegts
https://www.sau.com.au/forums/topic/139936-sold/#findComment-2635186
Also willing to:
Will you sell these seperate now?
https://www.sau.com.au/forums/topic/139936-sold/#findComment-2636356
  • 2 months later...
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
