my brother in law bought a skyline the other day from an auction for $13k
i am a bit suss about it because he said it has a turbo but when i asked him if he had checked to make sure it was a GTS-T (because it was debadged) he hadnt.
my questions are as follows:
how much difference is there between a turbo and non-turbo?
has anyone here tried to turbocharge a GTS before?
should it give the same results as a GTS-T?
will this affect insurance because it is not a factory turbocharger?
also, are there any good insurers that will let you insure under your wifes name (better history and a year older) but not include your intimate details (bad record) but still cover you to drive it?
(sorry, but i dont know the turbocharger type in case anyone wanted to know)
so many questions any help is appreciated
thankyou all for your time
https://www.sau.com.au/forums/topic/13995-maybe-not-a-bargain/
i always thought puttin a turbo in n/a engine is a bit iffy cauz the compression ratios r different and to do it u'd have try and change the gaskets and stuff to get the right ratio. as far as performance goes unless u match the ratios then u can run the same boost as standard otherwise u have to run lower boost to avoid damage which means less power?? if i'm wrong in this ....then please correct me....
i reckon just car insurance is pretty good for modded cars but i think they check nominated drivers records.
jay
Yeh i think ure right on the money there m8. I think from stories ive heard that its cheaper, easier and more reliable to just sell the car and buy a turbo.
U are looking at a hell of a lot of work to make a it a T and in the end its just not worth it.
Guest Boxhead
mas 2 - i know this sounds basic, but have you confirmed it either way if its a factory gts or gtst yet?
easy way usually is to check the wheels, 4 stud = non turbo from factory, 5 stud = turbo(however, could have had stud conversion)...
but thats the easy way i can think of... also, have you confirmed it has a turbo in it?
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
