The Razo gear knob I bought a few years back had circular grey plastic inserts of various sizes. There was no thread on them, but it turns out that I was supposed to choose the appropriate size insert and then"screw" the knob down - effectively creating the thread inside the plastic. (softish plastic) It was some kinda - one size will fit all approach...
Maybe your's is something similar?
yeh, what u do is choose the 10mm or 12mm.. cant remember, just test it on the knob.. one will be just a bit too small to slide on.. use that... then u put it in the gear knob, screw it in at the end, then just put on your stick and keep turning till shes tight..
easy as :P
if u want, i could look for my original razo instructions.. but its pretty easy.
Well, in my gearknob it has a few rubber inserts that I can choose to fit on the gearstick, then push in the knob and uses three allen screws to hold it into position.
I ended up drilling a bit into the gearstick shaft when tightening the sharp ended nuts, but good thing is they stop the gearknob from moving up/down or twisting. My bro screw it onto the rubber, which does not do any damage to the stick, but now after a few months his gearknob is a little bit loose again.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
