I have a R33 GTST 94 mdl, I want to swap for a less sporty car. hears some info on it.
: tein coil overs
: cusco 6 point rollcage
: cusco strut brace
: Hicas lock bar
: Drift style rear wing
: C west 3D gt wing
: 19" by 9" wheels
: audiobahn splits
: audiobahn 12" sub in perspex box
: audiobahn mono block 600rms@ 4om
: cadence 2 chanle 75 RMS per chanle
: Blitz 3.5" exhaust from the turbo back
: 600 by 300 by 100 intercooler with polished alloy piping
: Razzin volt stableizer kit
: Autometer boost gauge and water temp gauge
: Exedy single plate brass button clutch
: reco gear box
: custom stainles intake pipe
: Pod filter
: 4 steering wheels 1 nardi, 1 OMP, 1 RIGEL and the standard one
: 1 Trust gear knob and 1 Impul gear knob
All the aftermarket mods on the car have all been bought and fitted in the past 10 weeks,
I bought the car as a stock as a rock about 4 months ago and did all the work from there.
the car is white and is in verry good condition, it has 80,000 genuine kms on the clock.
The only problem with the car at the is that some paint came off the bonnet and front bar,
because when the car was imported it had stickers all over the front of it and when I went to
pull them off the paint came off with them. the front of the car will all be being profesionaly
resprayed prior to the sale of the car.
The only other thing that i woul have done to the car was a power fc computer, because with the
cooler exhaust and high flow turbo if you got it tuned with a power fc and put more boost
into it the thing would make realy good power.
I dont realy want to sell it but I am starting a new careea as a realestate agent and i need
some sort of 4 door car that is a little bit classy and a lot less sporty
the sort of cars Im interested in are
: A commodore preferably a vt or newer but mabee a vr vs HSV
: A BA seiries ford
: A BMW of some sort
: A merc of some sort
: But I will consider anything.
I should add that the skyline also has all the standard parts like cooler, piping, ruber intake pipe,
and all the other goodies. It also has about 10 mnths rego and I may arange a RWC.
PM me or call 0398907237 ask for sean
These pics are of the car when i bought it and it was stock as
Edited by WHITE R33
consider an A4 audi? I sent you a pm. I have had a cash offer on the 33 and I will find out if that is going through in 10 mins if it falls through I will be verry keen on the audi
i have AN of its head vl turbo holden calis series 2 with 3 sets of rims spares cost me over $30.000
in 3 years. [email protected] if intrsted email me a can send pics full specs under 12 sec car with the works custom everything some of the best mechs in melbourne have built it t66 turbo over 250kw
How much if it were to be straight sale, without all audio stuff?
PM me if you prefer
Cheers
Grant
  • 2 months later...
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
